Car is BROKEN
Old 11-29-2010, 01:13 AM
Fits_of_Fury's Avatar
Car is BROKEN
Came back from a long road trip today, just inside the city my poor car made an awful grinding sound then went dead. Engine turned over but would not start, did not sound right at all. Console lights starting blinking erratically, and some weird beeping too. I think my poor fit is done.
Old 11-29-2010, 01:45 AM
spin out's Avatar
damn.
and to think i'm annoyed because my suspension squeaks.
good luck.
Old 11-29-2010, 01:58 AM
Hootie's Avatar
Care to elaborate in greater detail on what was going on prior to the break down? Like any specific noises coming from a certain area, fluid levels, etc.
Old 11-29-2010, 10:33 AM
hayden's Avatar
First major GE problem I've seen show up on this board. I don't know - might have been a few lemons out there, but so far, complaints about the reliability are almost zero. Of course, fluid levels and all that would be interesting to know more about. Hopefully you will get more info from the mechanic. Sorry to hear!
Old 11-29-2010, 10:35 AM
M4psycho's Avatar
The blinking erratically and weird beeping sounds like the battery is dead to me...since I've had that happen. But you say that the engine turned over? .....go to the dealership and let us know what happened!
Old 11-29-2010, 11:17 AM
It's at the dealer now, they are trying to get a look at it today although they are busy. Oil was just changed and fluid levels were all OK. I could not see any visible signs of damage under the hood, or any fluids coming out from underneath. The grinding only lasted a second, I'm not sure where it was coming from. Will post when I find out more.
Old 11-29-2010, 05:58 PM
hkfooey's Avatar
Sorry to hear that bro - since I also have a 2009 MT... hope is not a bad lemon for everyone.
Old 11-29-2010, 06:42 PM
Trish's Avatar
i've just been struck with the same misfortune with my 07 gd3... check engine light came on car sputtered and died. let it sit a few minutes and she started back up but ran like ass continued to sputter and had no acceleration...brought it to my buddies shop ran a diagnostic and had a misfire in cylinder 4 had a compression test done with scary results she's dead!!!!
Old 11-30-2010, 05:24 PM
sooznd's Avatar
how many miles on your car? Could it possibly be a bad fuel injector?
Old 11-30-2010, 06:04 PM
Austin2010's Avatar
If the results of the compression test were bad then the injectors are the least of the problem, although possibly related.
Old 11-30-2010, 06:17 PM
dungther's Avatar
I cant wait to see whats happended to his car....
Old 12-01-2010, 05:44 PM
yuwan63755's Avatar
What did the dealer say about your vehicle? Hopefully they have had time to look and resolve the issue.
Old 12-01-2010, 06:22 PM
DiamondStarMonsters's Avatar
Why create a thread if none of you (F_of_F or Trish) are going to post any details... just wanted to vent and b!tch about it? lol
Old 12-01-2010, 07:00 PM
JaStonE's Avatar
its probably something stupid like a spark plug got loose
Old 12-01-2010, 08:25 PM
Trish's Avatar
sorry if I haven't responded fast enough to suit your needs but I work full time and have two kids so my time is very limited! with that said the car has 118000 km and the compression test's results were: 200lbs cylinder 1-150lbs cylinder 2-180lbs cylinder 3-200lbs cylinder 4... when i ran a diagnostic it read misfire cylinder 2 and 4 so I switched the #4 coil with the #1 and took a drive re-ran the diagnostic and it read misfire cylinder 4 which is strange cuz there is obviously a problem with cylinder 2... so at this point i'm going to inspect the wiring and my mechanic is going to do a wet test see what happens
Old 12-02-2010, 02:16 PM
sooznd's Avatar
Trish- is your Fit still under warranty?
Old 12-02-2010, 02:42 PM
Well that is certainly a reasonable reaction to a comment made in jest.
Good Luck.
Old 12-02-2010, 07:08 PM
Sorry for the delay, I have been dealing with a lady at the service desk and it has been difficult to get details.
So far it sounds like a broken valve spring, but I can't be 100% certain of that. Apparently they have ordered a new "block" and are working on it now. I can't give any more details, but when I get the full report I will let you all know.
For the record I drive my car hard but not stupid, regular oil changes with synthetic and no intentional red lining. I was not doing anything out of the ordinary at the time of failure. Engine had approximately 97,000km on it.
Old 12-02-2010, 07:37 PM
Trish's Avatar
no I paid the car cash so I didn't bother with the warranty...
Old 12-02-2010, 08:30 PM
phogroian's Avatar
Doesn't the engine have a 5 year, 60,000 mile warranty?
Quick Reply: Car is BROKEN
