Spotlight laminate - Cheap & Easy !
I wanted to protect my spotlights from stones but 'Laminex" is not available where I live. Here's my solution. Pic 1 - Buy a yellow plastic ring folder from any stationery store . Pic 2 shows that it's 90% transparent. Cut a piece out, remove the spotlight cover and place behind ( Pic 3 ). Replace cover ( Pic 4 ). The plastic is held in place by the cover. Total cost - US1.50. Total time to install - 20 mins. Time will tell if it discolours ( or melts ! ) but there's enough material to do both spots 4 times !! so if it fails miserably it's not been a major cost.
Thanks for the replies. The plastic won't melt, initially it softens then hardens with the heat. For 12 years I've been using a similar materiel as coloured filters in 12v spotlights in a commercial bar - these lights are on for 10 hours per day, 7 days per week. After about 4 months some of the colour bleeds out around the center. However, I don't use my car every night and don't always have the spots on when I am driving, plus there's cool air blowing against the plastic when driving so I think I'll get at least 6 months usage before having to replace them ( which is a 15 minute job ) . As the A4 folder will do both spots 4 times it means that I've protected my spotlights from stones for 2 years for USD 1.50 - I can live with that, I'll keep you posted.
Hi khfooey. My spots were supplied and fitted by Honda but they're not Honda original so I don't know if my fixings are the same as yours. Look at my installation photos - on Pic 4 you can see one screw hole, the other is lower down on the other side. By removing these the cover comes off ( Pic 3 ) and I don't have to touch the spots. Hope this helps
raymondchen625@gmail.com
12-07-2015 03:31 PM
cruiserandmax
11-24-2009 09:45 PM
boyetssilverfit
40
11-13-2007 12:19 AM
