Seats - Lateral Support
![Question](https://www.fitfreak.net/forums/images/icons/icon5.gif)
There was a recent Car and Driver article on the Fit vs. Mazda 2 vs. Ford Fiesta. The reviewer complained that the 2010 Fit seats had too much lateral support. I was surprised because, when I sat in the 2010 Fit, it seemed to have less lateral support than my 2007 Fit. Maybe it's because I'm a skinny guy, that the GD Fit seats seems to have more lateral support than the GE. Do any of you notice this as well?
Anyways, I still think that both Fits seats don't have enough lateral support. Honda should put Recaro type racing seats in there!
a reviewer complained that there is TOO MUCH lateral support in the fit? i have an '09 and i can't imagine the seats being too different in the '10 but... there is no way that there is TOO MUCH lateral suport in the seats. i actually think i had more support in my '01 mazda tribute
The back is fine, but it's a bit too aggressive in the bottom... it tends to put a lot of pressure on your right leg unless you have your legs straight out (I.e. not splayed), and you need a lower seat with more forward space to do the "straight out" position unless you have short legs.
The lateral support should be "gradual imo", or better (but expensive), adjustable. I have this on my mr2, it's cool for lapping, I can have the seat tight.
I also disagree that lateral support is lacking in the GE. Pulling some impressive lateral g's (thanks to the factory Dunlops), along with the grippy cloth, lateral support is good.
I sat in a Mazda RX-3 R3 with the Recaro seats and I could barely fit due to the ridiculous lateral contouring.
If anything, the lateral bumps on the seat bottom push against my left hamstring when I press the clutch.
