what grade of gas do you give to your fit?
#281
When he was talking about stop-and-go, he's talking about bumper-to-bumper traffic where the engine is running all the time, but the car is not moving very much. As I'm sure you know, the obvious benefits of premium are only seen during medium to hard acceleration, which is impossible in that kind of traffic. That's why I said he probably wouldn't *notice* the difference.
If you noticed my second paragraph, I noted that stop-and-go in hot weather changes things. It heats up the engine and the engine bay so much that the computer starts pulling timing even during normal acceleration. You *will* notice the difference with 93 under these circumstances.
I don't claim to know anything about *quality* differences of 93, 89, 87, etc. I leave that to those who do know.
However, you are right. I have gone on record as saying that there are benefits to using 93 in Fits, and I continue to be of that opinion. I'm just saying that some people are not likely to notice it during their commute. My mantra has been, and is still:
Try it for a few tanks, and see for yourself.
#282
I filled up last week when I was just below half with Shell 93 and the OBC is already showing an increase in mpg and its been in the low 30's in the morning and low to mid 40's for a high. I think I'm sticking with premium from now on. I'm going back home to Detroit next weekend, so we'll see what my freeway mileage goes up to. I know its colder and the air is more dense, but we'll see.
Another one of my trip updates will be posted here next week after I get home. I got 39 going there and 41.5 mpg coming home last time, so we'll see what I get this time with full premium fuel, cruize on in the right lane going 70 mph, this is what I always do
#283
I just got a bad tank of gas, premium will make the car run like it was suppose too with out knock, engineers put knock sensor on to prevent damage but at a cost of lower power and mileage. I expect to see a 10 percent decrease in mpg all winter because of the cold. I will explain this later in a new post when I have time.
#284
You guys up north differ from the guys in the south in seasonal fuel usage but I have a hard time believing it is due to the density of colder air and think it has more to do with the use of snow tires, road conditions and accessories like heaters, air conditioners and lights in addition to longer and more warm up time for the engines.... I plan to drive a couple of hundred miles Monday and will be leaving early before sunup so I will top off my tank before leaving and on my return trip to see what kind of difference occurs, if any.... The early morning temperatures are in the 40s right now and afternoon in the mid 60s.
#285
Short trips in winter will kill mpg more than warming it up once to clean windows and driving your normal commute. Never had snow tires and wonder why its a big subject, except to protect stock rims. I never had any problems going through snow and slush in my Fit. I went down streets that would surprise most of the people on this site with no problems.
#286
Nice find. I'm surprised at the Thursday special.
That's about an hour and a half away from me, so not too far, but I'd have to schedule at least half a day for it.
Also, they say AT's can be tested, but they say "some finessing is required. It's pretty simple."
I'm actually quite curious about this, but the one thing that concerns me more than anything is that their dyno chart screenshots start at 2500 RPM. I'm not sure there's any real difference between grades that high. I only notice anything down below 2000. Looks like a phone call is in order.
And no, I'm not that embarrassed
You can dyno an auto, you have to disable the traction control. I found my dyno results from 2 years ago and did very well. This is a dyno of GD3 Fit with vtec Jazz 1.4 & 1.5 i-DSI Power If you look at the stock hp and then compare it to the build up you would agree that running premium does benefit. I had a stock Ge3 Fit with a vtec, manual. Here are the numbers and when I get my scanner fixed I will scan it. 91.1 horsepower at 5800 rpm and 88.31 Torque at 4800 rpm all stock running BP premium at 6000 miles on car. Sorry wrong one http://asia.vtec.net/hardcore/JazzPower1/index.html
#287
My lifetime AVG right now is just over 38mpg and My last few tanks have been high 38s & lower/Mid 39s (our average temperature has been around 40 degrees when I'm driving.) When the AVG temp is in the 70's or 80's I'm up around 40 or 41+mpg. As we get into the winter I'm expecting to see 36 or 35 like last year with some really cold spells at or below 0F. The car is garaged in the winter so the starting temp when I leave in the morning usually doesn't get much lower than 32F but the drive is at times below 0F (usually in February).
If I were to guess, the 6-8mpg difference I see between summer & winter is probably 50% due to Temp and 50% due to other reasons such as different gas, Idle/warm-ups/clearing of snow.
~SB
#288
When the air into the intake is denser the ECU is going to adjust A/F ratio no richer than it would when the air is warm and isn't as dense so the amount of throttle opening needed to accelerate and maintain speed will be less..... I can remember an older thread where a guy blocked off his grill and did get noticeably better fuel mileage which supports what you are saying. Already this year I am seeing better fuel mileage due to lower temperatures....I have been seeing higher speeds at the same throttle position on days when the temperatures are relatively low.... My car is far from stock right now but when it was stock I noticed the same thing... The higher wind speeds during the winter is going to have a negative effect even when blowing from the side.... The amount of fuel mileage loss when driving into a head wind will be slightly over compensated for on the return trip where it is to the rear of the car.... My last tank of fuel yielded only 31.7 MPG but I believe this tank is going to be better.. If not I will reconnect the throttle body heater and possibly install the stock heat range spark plugs.
#289
#291
Okay, I just got back a week ago from a road trip to Nebraska. For the trip, we used 89 octane for the price advantage over 93, since it was mostly going to be highway miles. At a speed range of 60-75, and an average of 65 MPH, we got 36-37 MPG over 1,100 miles, per ScanGauge. Response was good overall, although not quite as snappy as with 93.
I noticed that most places along the way, and in Nebraska, didn't have 93 octane fuel. 91 or 92 would usually be the highest. This seems odd given the low altitude.
Also, in Nebraska, I noticed there wasn't always such a large price difference with the various grades. In fact, on the return trip, I filled up with 89 octane, and noticed while driving out that 91 was cheaper! Put that in your gas tank and burn it!
EDIT: that station was in Lincoln, NE.
Also, as you might expect, there were more E85 stations in the Cornhusker state. Not as many as I would have expected, though. One in Grand Island actually had E10, E20, E30, and E85 to choose from.
We took it slower on the way back--about 55 to 65--and got 38-39 MPG as a result. The last tank was started in Tennessee, and I drove more nicely on the way home. I just finished, with 505.3 miles on the tank.
And yes, I just filled up with 93.
SECOND EDIT: I did fill up with a 1/3 blend of E85 once during the trip.
#292
Also, how in the heck were you able to drive less than 65 on a road trip, especially through Nebraska where its 75 mph in a good chunk of the state via I-80.
Even going through Tennessee I couldn't go that slow either but that has more to do with getting up and down those hills on I-75 if you go that way.
Your mileage is pretty damn good for this time of the year for sure, your doing something right
#293
I have read conflicting things regarding E85, but nothing conclusive; I'm running partial mixes of E85 as an experiment so others will have solid reports as far as whether it's safe to run in a Fit. So far, I've run mixes up to E40. The only problem I've had so far is a Check Engine light, which gave a P0171 code (Long Term Fuel Trim Lean). As I understand it, the reason for the code is all that extra oxygen from the ethanol; it's not actually running lean. I don't know yet whether our fuel injectors could cope with straight E85, since they'd have to flow 30% more fuel.
Road trip speed: I had 2 other drivers sharing the load on the way there, and 1 on the way back, so it wasn't that bad. As for me, personally, I find it pretty stressful to drive very fast, so I actually have better endurance if I go around 55-65.
And yes, those Tennessee hills were pretty bad, especially with a full load in the back.
I attribute my good mileage to good driving habits, driving a manual, my modifications to the car, and higher tire pressures (44 front, 48 rear).
#294
I found some more info http://www.state.mn.us/mn/externalDo..._E20Report.pdf Its a good read and goes into the problems. I will continue to use 93 octane gasoline.
This is another reason to use premium gas http://www.crcao.com/reports/recents...9%202%2004.pdf As the gas sits it the tank it loses the light ends reducing octane and raising the need for higher octane. Ethanol seems to speed this up too. All this on top of colder weather and longer warms ups reduce the mpg of any car.
#295
55 on the freeway isn't for everyone but if your comfortable with it and don't care about the looks you get, good for you! It does remind me of that one commercial for Castrol, I think, where the guy has an anchor dragging behind him on the freeway
Now your air pressure is ok if the tires can handle it but man it must be a bumpy ride for sure. I run 36-37 psi all the way around during the winter so I don't have to worry about losing psi with the cold temps here in Chicago. The only thing I'd worry about additionally with your psi settings is the middle of the tires wearing out because of over inflation.
The use of E85 is a little too risky for me to try, but what are those other numbers and letters you've put up for the E85, I'm not familiar with that
#296
From what S&D is describing, the E85, even 1/3 tank, puts the fuelling requirement outside the ability of the Fuel Trims to adjust for. This could lead to a seriously dangerous lean condition under load.
This would make me very hesitant to do this on a stock ECU. But I will be running the AEM by then so we shall see what the actual figures are for various blends or E85.
If I can find a way to get a second fuel rail installed, I would prefer to go E98. Nothing quite like unleaded, oxygenized ~114oct pump fuel!
#297
I'm very happy with my switch to BP Ultimate and I know the E85 is higher octane, so you boosted guys can really take advantage of that for sure. I know a guy back home that trailered his EVO VIII here to AMS and had the car tuned for E85....it puts down 375 whp on their dyno, amazing what an extra .4 liter and a hairdryer can do to an engine
Hell, just want another 30 hp/30 ft/lbs of torque and I'd be able to call it a day for this car
We'll see how my mileage does this week on the next fill up. Thanks for all the info supplied here, I know I find it interesting and its very informative too!
#298
Here more info on ethanol blends in cars http://www.ethanol.org/pdf/contentmg...inal_12507.pdf not what I was looking for but will keep looking.
#299
Thanks for the links, SilverBullet.
@Klasse Act: the term E85 means 85% ethanol. The rest is gasoline. They reduce it to about 70% during winter months. I use the term E40 to refer to a blend which I calculate to be 40% ethanol. If you make such a calculation, remember that the "normal" gasoline is probably 10% ethanol, or E10.
#300
Heres more info from the epa http://www.epa.gov/otaq/presentation...-isaf-no55.pdf, http://www.afdc.energy.gov/afdc/etha..._research.html
