Valentine One Hardwire... Where? How?
Hi Guys,
I'm a complete noob when it comes to hardwiring but after 2 tickets in 1 month I think the time has come where I need to splash some money into a radar detector.
That said I dont want to use the cigarette lighter to power it up and want to hardwire it.
Ideally I would like to hardwire it but also be able to "snap" it off when I need to take it off the car easily to move it to another one. And of course quickly "snap" it back in when I bring it back.
Any ideas on how to get this accomplished?
Know anyone in the LA/OC area that maybe able to do this for relatively cheap?
Thanks again!
Thanks again!
hmmm... when you say hard wire, its usually permanent. unless you have 2 sets of the power supply cord.
check out specboy's car domain page on his sig on this thread
https://www.fitfreak.net/forums/2nd-generation-ge-08-present/58391-new-fit-owner.html
Thx Punisher.
Woo, Nice choice of Radar. Mine is 11 yrs old and still going strong - still on the original suction cups too. - Been hardwired in 3 vehicles (2 integras and the FIT) and gets moved to the Ridge with the Cig adapter for long trips.
As for the install... it is EASY! - if you can work pliers, you can do this.
what you'll need is:
I actually have photos for a DIY, just never threw it together. I'll see if I can do it tonight or tomorrow. Don't have the Concealed display mounted or hardwired yet so I can only do the Radar portion now. Will add the CD at a later time.
~SB
- an "Add-A-Fuse" from your local autoparts store.
- Extra Fuses - (Add-a-Fuse doesn't come with any)
- A 9' 4-wire phone cable (6' works but is tight - no slack)
- A 6' 4-wire phone cable (if you are mounting the concealed display as well)
- Either A Soldering Iron and heatshrink tubing (or some buttsplices and crimpers)
- About 1 hour of your life that a significant other can do without.
~SB
if you tap your map lights wont the detector always be on?
Ideally I would like it so that only when the ignition is on the detector will turn on...
Please, do post a DIY on this.
I had the V1 with concealed display hard wired into my Marauder. I don't want to tap into the ignition wires on my Fit(s) so it's been sitting in a box.
Hook us up.
Hook us up.
Thx Punisher.
~SB
~SB
I installed a custom switch which is linked in the 1st post and in my sig.
I can't find my photos from the V1 install which is a bummer but I'll see if I can take a photo or two of the fuse box. I used the 12V accessory (Cig lighter) and put a 20a fuse & 5a fuse in the add-a fuse. The 20 to replace the stock 20a that was in there, and a 5v for the V1 Hardwire. (the v1 has a 1a or 2a fuse built inline anyway so now it is double-fused)
~SB
Thanks
They are the mini but the "low profile" mini so they don't have the two spades that stick out of them. The Mini Add-A-Fuse works as I have one on mine but you can't use the stock fuse in the add-a-fuse, you have to use two standard mini fuses.
~SB
~SB
Thanks greatly for the info! I already ordered the add-a-fuse mini version from Amazon along with the hardwire kit so I should be OK. I wondered if I could use another add-a-fuse to create an under dash cig lighter for my GPS? I don't see why not! That would free up my cig lighter in the console and make things neater. Thanks again for the information.
For those who are interested, I did a How-To on the V1 hardwire install and slapped it both here and on my Cardomain Page. Page2
https://www.fitfreak.net/forums/2nd-...tml#post903938
http://www.cardomain.com/ride/3368795/2
hope it helps everyone.
~SB
