offset...Every GE8 Member Post NOW!
Old 10-18-2011 | 10:04 AM
xSimply's Avatar
Wheel Size: 17x7
Offset: +43
Tire Size: 215/40/17
Suspension: Swift springs
When I Rub: No Issues
Last edited by xSimply; 11-11-2012 at 02:56 PM. Reason: suspension has been upgraded.
Old 10-18-2011 | 10:57 AM
SSMTEN's Avatar
Wheel Size: 16x7
Offset: +40
Tire Size: 205/45/16
Suspension: Apexi N1 Damper. Lowest setting. Its probably at least 2inches lower than stock height.
When I Rub: Up front only. On medium size dips and bumps. Also when I have multiple passengers, I rub when making turns. No fender mods.
Old 10-18-2011 | 01:49 PM
j1nNju1c3's Avatar
Wheel Size: 17x7.5
Offset: +40
Tire Size: 205/45/17
Suspension: Apex'I N1 Damper. Lowest setting with camber bolts -1.75 degrees (still need to be aligned)
When I rub: I rub on large dips on the front. Rears rub with passengers since I have 10mm spacers. Fronts are pulled, but will be rolled in the future. Same as the rears
Old 10-18-2011 | 08:00 PM
beezle's Avatar
I am far from an expert in this type of stuff but my understanding is that offset alone is somewhat meaningless as fitment also depends on the style/shape of the rim too, ie two rims with the same offset may not give the same results.
Old 10-18-2011 | 08:26 PM
SSMTEN's Avatar
To the contrary, offset is one of the biggest factors. "style/shape" are themselves dependent on the offset.
We dont want to clog this thread, so here read this link. Educate yo'self. --> Wheels and Offset
If you have any questions, feel free to PM me or anyone else. Or use the search button. There are a lot of offset threads in this forum.
Old 10-18-2011 | 08:47 PM
beezle's Avatar
Funny you should post that site as it was one which a tire/wheel firm specifically mentioned as putting out less than complete information and causing problems for people who are so certain they 'understand' when in fact they don't.
Old 10-18-2011 | 08:50 PM
1SickVeilsideZ's Avatar
How about we add some pictures to the thread as well when posting the specs?
Old 10-18-2011 | 09:18 PM
JJIN's Avatar
Wheel Size: 16x6.5
Offset: F/+44, R/+39 (5mm spacers in rear)
Tire Size: 205/50/16
Suspension: buddyclub N+ coilover, -2* front camber and super secret toe setting, 2" lowered in front and almost equal lowered in rear.
When I Rub: highway speed semi deep dips, tire squealing high speed/ high load turns.
Old 10-19-2011 | 12:34 AM
DocCCVp's Avatar
Wheel Size: 17"
Offset: +45mm
Tire Size: 205/40/R17 (Toyo Proxes)
Suspension: 1.4" Front Drop, 1.2" Rear Drop
When I Rub: Never, not even with 4 people and luggage. =)
I will confess that I added a Rear Spacer @ 1/4" and I had to slightly roll the rear fenders. Still never rub after the roll.
Old 10-19-2011 | 12:44 AM
SSMTEN's Avatar
Have it your way. Im not the one who thinks offset is meaningless
Old 10-19-2011 | 01:35 PM
kevinkidstar138's Avatar
Originally Posted by Virtual
Don't see why every GE member needs to post but:
15x5.5
175/65R15
Everything stock
No rubbing
Originally I posted this (well over a year ago) lol, because it was around the time that everyone said that 40+ or lower offset would rub, so I wanted everyone to post, so people could see different set ups and what works and how it works!
  #32
Old 10-19-2011 | 01:38 PM
Java^FiT's Avatar
lol nothing like coming back from the dead
  #33
Old 10-19-2011 | 01:41 PM
great idea, nice to see this thread back from the dead
Note: and i will stop convo after this
to the guy who asked about 16x9
FITDEEZ runs 16x9 all around, have seen it in persona and I personally do not think the poke is too much!
  #34
Old 10-19-2011 | 05:44 PM
12toothassassin's Avatar
Wheel Size: Base stock
Offset: Base Stock
Tire Size: Base Stock
Suspension: Eibach ProKit
When I Rub: In front when wheel is turned and hit very large bump
  #35
Old 10-20-2011 | 10:44 PM
jazzhands68's Avatar
Current
Wheel Size:16x7.5
Offset:+43
Tire Size:215/45
Suspension: dont shun me, but cut eibach sportlines
When I Rub:never
Past
Wheel Size:15x7
Offset:+20
Tire Size:205/50
Suspension:same
When I Rub:never
KennyisFez
06-24-2015 12:10 AM
here11
07-14-2010 10:14 PM
_dimsum
04-07-2010 12:27 PM
sedanimal
02-01-2010 12:29 PM
Skytraveler
01-31-2009 05:08 PM
