Cruise control in 2010 Base - problems
Ok that's what I pretty much expected. Thanks for the reply!
No. When I got mine I checked with the Rostra folks to see if I could use another Rostra control (they have an older wireless you can stick on the wheel) and they told me no way. The wiring and clockspring (inside the steering hub) are different for Base and Sport. There are not enough wires in the base steering column clockspring connector to connect to anything under the dash (OEM cruise, Rostra, prolly radio controls as well. I ended up taking apart the Rostra control-on-a-stalk (which looks like it was designed for a Soviet tractor) and doing way too much soldering and spaghetti wiring to move the controls to the dash; they don't have to be on the wheel.
If I can figure out how to add a link, I'll edit this with a link to a picture of my solution.
I am not sure if I am allowed to post links, but it is a link within Fit Forums: https://www.fitfreak.net/forums/pict...pictureid=4964
