Mileage - Real Life, regular vs. premium
#41
No BP either. No Tier 1 Fuels. Nada for 30-45Mile.
Mobile Stewart's Sunoco Gulf Citco. . . . others
Interesting detail on BP. Little less ethanol.
I'm not sure changing to winter blends helps anything.
I see no difference between the two. Only premium was the V-Power on my way to the city.
Love that fuel. Two tanks at least.
#42
#43
The GD-3s Have a compression ratio of 10.4 to 1 and I can tell there is a difference between the different octane ratings in both performance and fuel mileage as well low end torque on hills... That was when my car only had a short ram intake and larger diameter axle back pipe with glass pack muffler..... I now have the KWSC high boost kit and premium grade fuel is a must. Still I find that the reflashed ECU will advance ignition timing an average of 5 degrees with octane booster added to the fuel at cruising speeds at 25 to 30% throttle openings and accelerate to higher speed in the same distance at WOT... I have also noticed that using colder heat range spark plugs also increases ignition advance and have seen as high as 41 degrees advance on my scan gauge.... If you are looking for mileage increases with higher octane fuel while driving conservatively it isn't likely to happen because you are not asking enough of your engine but if you are the kind of driver that enjoys driving at high speeds and drive more aggressively you will see a 6 to 10% improvement, or at least that is what I have experienced with my GD-3 with manual transmission.
#44
Thanks, GW Fit , for the best data I have seen, and a pretty good argument that with a stock Fit, the difference in gas mileage between regular and premium are probably not statistically significant.
If I read right, you used both grades in each direction. Is it reasonable to assume that when you changed from one to the other, you ran until the tank was almost empty? 1500 miles in each direction is only about 4 tanks, so that sounds like 2 tanks of each.
Re the onboard mileage meter, over 5000 miles (since having the software upgrade), reported gas mileage has been, on average, within 0.2 mpg of calculated mpg. Differences have been as large as +-3 mpg, but I suspect that reflects operator error due to the difficulty of getting a consistent fill on a Fit (unless you are way more patient than I am). This is confirmed by the variation being greatest on fills when the tank is more than 3/4 full, vs nearly empty.
My final observation is that gas mileage seems to have improved after passing 10,000 miles.
I tried to keep the mileage as even as possible with two tanks to empty on each fuel and then switch on empty. My mileage numbers vary as I went over several higher mountain passes on I-5 and would then follow it up with stretches of flat valley driving. Temps were pretty constant and I hit almost no rain. Also all fuel was summer blend.
I have noticed a slight increase in mileage over time and a decided decrease with winter blend. Almost 20K so I think my little Fit is broken-in by now.
2010 Taffeta White
5spd Sport
#45
[QUOTE=Texas Coyote;882515]The GD-3s Have a compression ratio of 10.4 to 1 and I can tell there is a difference between the different octane ratings in both performance and fuel mileage as well low end torque on hills... That was when my car only had a short ram intake and larger diameter axle back pipe with glass pack muffler..... I now have the KWSC high boost kit and premium grade fuel is a must. Still I find that the reflashed ECU will advance ignition timing an average of 5 degrees with octane booster added to the fuel at cruising speeds at 25 to 30% throttle openings and accelerate to higher speed in the same distance at WOT... I have also noticed that using colder heat range spark plugs also increases ignition advance and have seen as high as 41 degrees advance on my scan gauge.... If you are looking for mileage increases with higher octane fuel while driving conservatively it isn't likely to happen because you are not asking enough of your engine but if you are the kind of driver that enjoys driving at high speeds and drive more aggressively you will see a 6 to 10% improvement, or at least that is what I have experienced with my GD-3 with manual transmission.[/QUOTE
That interesting so I am driving wrong. I will run my car harder this week and let you know. The humidity came down and my mpg going to work was 47 mpg on scan gauge. I have the gauge set up right no corrections the last 2 tanks. The van I went on vacation has a low compression motor 9.5to 1 and probably has a static compression of 8.0 to 1 and you can still notice the difference even in winter.
#46
Glad to hear that they put dino in at the factory. Now I wonder whether the cars that the factory recommends to run on synthetic, don't actually use dino to help things break-in. At least when it comes to piston rings, I think a little friction is good.
My big test comes with a well broken-in engine, all oil changes just after the "mileage minder" went to 15%. I'll put in the synthetic and measure mileage again but won't do another 3.5K highway trip until next year.
At what mileage, would you guess, will your engine be broken-in? I'm thinking 15K.
K_C_
#48
Shell has a pretty extensive network in the NE, and BP has just started opening up tons of stores around my area. All other places generally use less refined "budget" fuel that is a blend from multiple refineries and regions. Here is a list of top tier gasoline suppliers that I'm sure a lot of other people use outside of the NE region - we just don't have anymore here;
More specific info here. Top Tier Gasoline
76 Petro-Canada
Aloha Petroleum Phillips 66
Chevron QuikTrip
Chevron Canada Rebel Oil
Conoco Road Ranger
CountryMark Severson Oil
Entec Stations Shell
Esso Shell Canada
Exxon Sunoco Canada
Kwik Trip / Kwik Star Texaco
MFA Oil Co. The Somerset Refinery, Inc.
Mileage Stations Tri-Par Oil Co.
Mobil Turkey Hill Minit Markets
U.S. Oil
Chevron QuikTrip
Conoco Road Ranger
Esso Shell Canada
Exxon Sunoco Canada
U.S. Oil
#49
My next battle will be to find some decent rubber. Any suggestions?
#50
I believe an engine is almost broken in at 1000 if that, The reason I think this is the sensors are deteriorating the moment you start your new car. Engine are make to exact tolerances and ran on a electric dry run dyno to make sure its Ok to sell. The materials are more forgiving than steel blocks of the past.
#52
I remember in the past that you would have to change the oil after the first 1000 miles to get the metal shavings out, It takes about 1 year for the computer to set the long term fuel trims due to changing weather but thats not engine break in and the sensors are deteriorating at the same time. New engines are so complicated.
#53
Wow. Hard to imagine an engine being broken-in in just 1Kmiles.
I'm not thinking metal shavings so much as all those moving surfaces becoming seated. The tolerances are high and I interpret it as a 'tight' engine. All those surfaces still need to get to know each other real well. During this process metal is worn, more in the beginning. The amount is a whole lot less in today's engines and some mfg's are better than others.
From what I glean it's near 7-8K. My 15K is way off.
This recommended initial oil change sequence has opened my eyes to the technology present.
Honda is out of the synthetic oil business. [not for any models??]
Synthetic oil guys say switch over after 10K or so miles dino. That initial engine wear or break-in. Crucial to the longevity of the engine.
The sensors. Each monitoring system operates within an acceptable range of values.
All those codes represent something functioning to spec. If something go wack - it records that.
Could be a measurement going out of spec - a system failing - a sensor failing - all sorts of things. User is alerted something is up.
Not sure what/where sensor deterioration fit's in. It is designed into the system, no?
#54
I just checked my oil at 3500 miles it getting dark but when I put on finger theres a lot left. Mobil1 is factory fill in the Acura RDX . A new engine computer doesn't have the maps to run the car in close loop, that takes 600 miles to get enough maps to not hurt the motor. The carbon on the piston equalizes at 15000 but thats not brake it in. Any time you have electricity going into or fluids going across sensors it is deteriorating, That doesn't mean it not going to last 100,000 miles or more. I am not sure about synthetics any more, Ive put m1 in at 3000 on 2004 civic no problems at 45000 miles 38 mpg traded it for the Fit.
I guess if you put it all together and its around 10000 and call it break in, I guess I agree.
#55
You finish with a good point - call it break-in. What ever it means. I see it in simple terms. Honda makes the motor to a high standard. The forst 7-8K are with dino and all the parts 'seat' themselves. After that switch to synthetic. Better wear/life characteristics than dinon Honda has no issue with this, it's just interesting that they don't recommend synthetic oil.
#57
Is this the never ending debate? Premium vs. Regular? Of course when I bought my new Fit I felt obligated to experiment. I've stayed to "Top Tier" stations...in my area Chevron but tried full tanks of regular and premium. No scan guage, not much hard information to provide, but my simple empiracle feedback has been that I noticed little to no improvement in mileage with the premium, and I actually felt the engine ran a little rougher with the premium. Oddly and unexpectedly, I thought it ran smoother with the regular. So regular it is. I do not pretend to have the definitive, scientifically supportable evidence on this, but IMO if Premium doesn't seem to be aiding in mileage or in how your engine is running? Then why pay extra?
#58
If you were to disconnect the negative cable on your battery and reconnect it to reset the ECU after changing over you may or may not feel the difference and see an increase fuel mileage.... I am not going to say that you definitely will, but I did... I agree with not paying the extra money if no positive difference is experienced... It is hard to know how much of the added octane in todays fuel is from the percentage of ethanol being used, that stuff kills fuel mileage....All of the pumps in this area have a sticker stating that up to 10% methanol has been added to the fuel.... People are being killed by high fructose corn syrup and our fuel mileage is being killed by the same product being used in ethanol production..... Corporate greed sucks.
#59
Amen on the corn syrup.
all it's really doing is putting $$'s in some washing-ton farmers pocket
isn't doing squat for the environment
Them big boys - ConAgra - Cargill - Arcer Daniels Midland - Farmland - have us clean and simple. They are our government, at least they have bought congress. Put the oil boys next to them and you see where we are. Oh yea, don't forget Insurance and of course, the Lawyers and Bankers.
As to the ECU, I'm wondering how much of a learining curve it has to an individuals driving habit/style. I'm sure that my FIT is learning how I drive a bit more than I'm learning how to drive it.
#60
