keyless entry for base
I want to report that I am very happy with the remote key I got for around $40 dollars. I cut the key part off and easily programmed it in about 5 minutes. Now it is a nice key fob that will lock, unlock and sound the horn when I want to. I am very happy. I do not know why they would not just supply the key fob at purchase for a base car. Any thing to move you into the more expensive model.
thanks
rick
thanks
rick
Keyless entry for base
thanks
rick
thanks
rick
Do you need Honda Diagnostic equipment to program the key? or can you do it yourself? I saw a unit in the internet with pdf manual posted, but it looked like you needed special software and/or connection to do the programming. Thanks.
Keyless entry
I got the key from College Hills Honda. I cut the key part off and followed instructions to program it. Very easy. You turn the ignition on and off about 4 times and push on the lock button of the key each time. You can hear the door locks click on the the 4th cycle and you are done. Watch the video. Works great. The consol arm rest worked out well also. I have the base with MT.
later
rick
later
rick
all you ever need is this thread. read the first 3 page, or a few more for fun
later
rick
later
rick
Brain Champagne
07-03-2011 08:15 PM
