Oil: The debate starter.
Old 07-19-2010, 04:55 PM
wacky wick's Avatar
Originally Posted by nikita
Its not the crude anymore, and thats the great thing about modern refining. No one can use napthenics in ILSAC/API motor oil because of the reasons you stated. Even Group I solvent dewaxed paraffincs wont meet the standards for multigrades. All modern multigrades, which is all you should use in a modern engine, is, at a minimum, all hydroprocessed paraffinic. That gets rid of the aromatics, sulfur, nitrogen and waxes. The result is a naturally high Viscosity Index, requiring less improver, low volatility and high oxidation resistance.
I havent seen one of those toilet paper filters in decades. A guy at the swap meet used to sell them. I always worried that because TP is supposed to come apart in water, that combustion byproducts would break it down and paper fibers would end up circulating in the bearings.
In my opinion TP is only good for filtering water out of air in compressors, and thats not to good either.
  #142
Old 07-19-2010, 06:04 PM
Come on wacky we all know what it's really good for_
Any way, when i was in the USAF we called it APP. That's All Purpose Paper. One would be amazed with all the uses a grunt can find for it. Filtering oil was not one of the uses, however.
K_C_
  #143
Old 07-19-2010, 07:27 PM
wacky wick's Avatar
Thanks ChuckI got a good chuckle out of that, tp and electrical tape makes and great band aid too, one size fits all.
Dave
  #144
Old 07-19-2010, 08:34 PM
Roger's Fit's Avatar
Mahout, Thanks for clarifying that for me, The Beta ratings are what confused me,, That is what the Mann ML1008 filters have, just as good as the Amsoil Ea103 which they don't make anymore. I know what I will be buying from now on. As for the acid build up, I use Amsoil with a tbn of 12, and change it out around 6000 miles or 6 months which ever comes first.
I have spoken to Amsoil about the EA013 issue, and there will be a rerelease of a redesigned filter. You can read about it here.
  #145
Old 07-20-2010, 11:42 AM
SilverBullet's Avatar
2Fit2
02-18-2012 01:59 PM
Eugene.Atget
12-11-2010 07:21 PM
Selden
05-10-2010 02:08 AM
randomracer
02-05-2009 08:54 PM
phil_qc
09-06-2006 01:23 PM
Quick Reply: Oil: The debate starter.
