Dash cluster control things
Not quite sure what to call it exactly but the knobs on the dash that control the Air con and so on, which is the model which has the Electronic controls and does anyone know if its difficult to buy the controls and switch over? here's a pic
nope, but with a little bit of work, we might be able to import it and swap it in.
It might not a simple swap though. I'm still trying to figure out what is needed to do the swap...
They drive on the right which means controls that you want to swap would only be reachable to your passenger on your us spec car
Honda | Jazz | Galerie
I guess you didn't check my link. In Germany, they have LHD cars that also have climate controls.
For that, he can import JDM parts. You could try this link https://www.fitfreak.net/forums/2nd-...tml#post769550
thanks guys, the part whcih im not sure about being a direct swap is the lever to swap between recycled air and outside flowing air, cause that is manual on the regular model where as this is a button so it must be motorised somehow...
with that kind of time and money i would go for the skyroof project.
Yes - A Skyroof Project - how hard could it be? Finding the parts could be the most difficult. That's the slickest thing I've seen re: FIT Mods.
Alright guys, so I bought the climate control cluster.... this will be hard... Anyone know where I can get wiring diagrams of the JPN model which comes with the climate control and a wiring diagram of the standard.... I really want to put this to use, its very nice :P
It's possible but it may require a lot work. When I had my 97 Civic, I've always wondered if it could be converted to the 99 HVAC.
http://honda-tech.com/showthread.php?t=605432
Thanks for the reply, thanks for the link too, gives some perspective on the job at hand, I will be willing to do the work I just need diagrams, will help a lot, I'm thinking off pulling apart some of my dash this weekend and having a peek around to see what its like.
Even if available in North America, I wouldn't want these controls. One of the things I really like about the controls is that the air mix knob is continuously variable, rather than relying on fixed positions selected by buttons. This means that I can fine tune the split between face and feet in a way that isn't possible with a button system. The past 2 cars I have owned have all had automatic climate control systems with button selectors, and the Fit's big knob is a small but significant improvement.
I don't hate the knobs, I just like something different, thought it be a cool thing to change, and I was thinking about the cup holder, I'd like to get it eventually but I want to see if there are better after market ones released... its damn hard to find things for this car in AUS
