need some solid answers...
Hey, so i've done searching, and i've read the 4 or 5 threads on this topic, but i would like to hear some real answers. I'm looking at buying a set of lowering springs off of a GD to put on my GE. From what I've gathered, the top and bottom size are the same, so they "fit". In stock form, the GD spring is a stiffer spring and about 20mm lower than the GE spring. So, in theory, a lowering spring that drops a car 25mm on a GD will lower a GE 45mm, correct?
also, there are no aftermarket struts for the GE yet made for lowering. and the current lowering springs (t1r, tein, df210) are made to work with the stock struts.
i just need someone that has experience with either of these topics to chime in and let me know if i'm going to completely destroy my car if i buy lowering springs from a GD and put them on my GE. and please, if you're not answering the question, don't put stupid comments in here. thanks!
Yes, the springs will "fit" but be stiffer.
I'm not sure about the lowering levels.
But--is there a reason you want GD springs?
I have Swift Sport Mach Springs and I COULD NOT be happier with the drop, ride and quality.
I guess it depends on how low you want to go.
I hope you find your answers.
i have megan racing lowring springs for the gd and i put them on my ge and i love the ride almost no body roll and they are still with a good drop on the front i wish the rear was lower but its ok i guess kinda gives it that muscle car stance hahah but idk it works with my boso pipes
thanks for all the really great input guys.
about the GD koni's, I thought there was an ABS line or something (i honestly can't remember what it is) that was in the wrong place and would be really a pain to put on a GE. Is that totally wrong?
pearl
01-15-2016 03:33 PM
drumsauce
10-24-2010 03:26 PM
