engine oil - first change
I've put first 250 miles on the car in a week or so. Checked manual and it says - do not change oil which comes with the car until indicator shows less than 50% oil life (I think it is 50). it makes me think Honda did in fact put some additives to this first fillup. Nevertheless I do not believe this is right to keep oil for that long after engine break-in (lots of metal shavings collected after first few miles and It does not make any sense to run this crap for so long);
hence 2 questions:
1) when did you change yours?
2) would this void warranty in any way (stupid but ohh well) - can point to manual saying you did it wrong lol
I'm planning to dump this crap soon put fresh petroleum based from stealership and only then switch to synthetic.
thoughts?
hence 2 questions:
thoughts?
dark color does not mean oil is bad. but I hear you...
I think I'm gonna put few more hundreds and put fresh one in.
aye.. see I do not think it makes sense to put synthetic in just because I follow the idea to do 2 short changes with petroleum based oil. plus for new engine synthetic does not help to seal the rings nicely.. call me old fashioned but I do believe in proper engine break-ins. As usual I'm gonna run synth amsoil with recommenced weight. Always especially on my old B and K series I can feel how easily engine runs especially in high rpms
It's 15%, by the way, which for me came due at 10,000 miles. At 20,000 miles I've just done the second oil change. My Fit uses about a cup of oil in 10,000 miles, so I guess I broke it in okay.
There are a bunch of threads on this subject and as many opinions as there are members here, if you care to do some searching and reading.
I don't believe I am as smart as the engineers who designed the engine in the Fit and therefore if they say "don't change it until the indicator says so" then I am not going to change it until the indicator says so. Pretty simple if you ask me! 9,000 miles and still rolling on my original oil... of course 95% of those miles are highway miles, but I am still at 30% oil life, so I will probably need to change it in the next month or so.
I mean the Fit just got named one of Car and Drivers top ten cars again and won the residual value award...how can you argue against what Honda says?
to save you money? lol
if you ask me - this is bullshit to run same oil for 10k after breaking new engine in. but hey that's just me ) all I needed is to get some info on what ppl think and especially when they changed theirs based on oil indicator (sample data)
in regards of honda etc.. yeah I'm still shocked this car does not have proper coolant temp gauge.. just cold/warm corner cases. stupid if you ask me especially for engine with less power hence more stress -> more heat etc.. but ohh well
what oil brand do you run?
I use Motul. I know it may seem a bit overkill, but my tuner hooks me up. I 5 quarts for $30. Can't beat that. I'm using 5w-30 and Hamp Synergy oil filters.
hah! for that price...
so why do you think they specifically put this in manual - do not change before?
I don't think Honda says don't change your oil early just to save me money, I think it is simply what they deem "best" for the life of the engine. With that said I will tell you that a lot of BMW owners "feel" that the reason BMW has 15K oil changes is because maintenance is free for 4 years, 50K miles. So BMW, theoretically saves money by pushing out the oil changes. However, a lot of other BMW owners believe that BMW knows exactly what they are doing and would not put their reputation on the line to save a few bucks. I tend to fall under this philosophy. I don't think Honda would do something that would risk their reputation.
With all of that said, I will say this: I also believe that you can do whatever you feel like doing, it is your car after all. Enjoy your car and change your oil as often as you would like.
My other car is a BMW and it has 10K or 15K oil changes (can't remember which) I just go when it tells me to go. There are a lot of people that have a hard time following this advice, because it goes against the old "every 3K" philosophy.
Do you know how many quarts your BMW take? You will be surprised ) So yeah I think BMW can be overestimating build quality lol anyway hey 4y/50k free maintenance - all what happens beyond that is to owner's expense.
But like you said - it is personal opinion I think.
Did my first at 7,500 when the gauge was at 30%. Used royal purple synthetic with whatever the recommended weight Honda suggests and a Wix filter. Plan to do it every 7,500... mostly rough city driving.
Did my first at 7500 miles, with 40% showing on the MM. Since then, I've changed at 15% on the MM, which has been roughly 10k miles between changes. 7500 did Mobil 1 5W20, 17,500 more of the same, 27,500 changed to Pennzoil Platinum....Wix filters (NAPA Gold) the whole way.
iam changing mine at 10k.. iam at 7k now almost there. Iam trying to let that pre-factory molybdenum disulphide oil soak in really good to seal up those rings... but truely its up to you... the only other vehicles that has this type of engine treatment is motorcycles.. so iam sure it won't hurt it if you didn't properly treat the engine and take it out early...
all the DOHC Vtec motors don't have this molybdenum disulphide in it and they are fine...
EDIT: oops not sure if its moly disulphide, i ment to just type Moly. sorry if iam mistaken
