My engine seems to have gotten louder
Low frequency noise at open rear window is the flow of lots of pulsating air rushing by causing flow separation along the side of the window, starting at the
A(front) windshield pilar. A vertical deflector placed at the frontof the rear window at the B pilar will reduce pulsating , but increase constant ''swish'' noise.
just posting this aain coz im really hesitating to bring my car to get a diagnostic test and spend too much only to find out its just a minor problem or a simple adjustment..
" i have a 08 honda fit with 42k miles..i started noticing this motorboat-like sound everytime i drive, especially on the freeway and it bothers me so much.
what do you guys think about this prob??? "
and the sound is coming from the rear... is it the axle?? somebody is mentioning about the heat shields, which i dunno where theyre located..
help. thanks alot
help. thanks alot
I have been having the same problems recently. I tend to notice it at idle as well. Had the Fit since Sept. 2009 and it has about 24,000km. It always seems to be at higher RPMs. When I'm going downhill and have it at 3rd gear, the whole gas pedal is shaking and with the louder engine noise than before.
Not sure if you have this problem as well, but there has also been a weird smell coming from the fans, especially the ones close to the windshield. Not sure if this would have anything to do with the noise as well or maybe the air filter?
mozarwasagenius
04-05-2009 03:47 PM
