My first experience with Lift-off oversteer in the Fit.
A larger rear sway bar will absolutely make the car more tail-happy, and will increase the likelihood that the inside rear tire will lift in hard cornering. VW Golfs, Jettas, Foxes, etc... up through the MK4 all use a torsion beam rear axle similar to the Fit's, and love to lift that inside tire in autocross/track use.
By letting off the throttle, you shifted the weight towards the front, thus making your rear tires lose traction. You were probably going in a little too hot. If you want to push your GE8 to the limit, take it to the track. Luckily you didn't get hurt or get anyone else involved.
gts1985
04-01-2008 09:17 AM
