Tire Pressures
recommended pressure is the best for most
I have played a lot with tire pressures over the years, and after much time and effort, I've decided the manufacturer's recommended pressure really is the best.
Lower the pressure by 6 lbs or so, and you'll notice a cushier more comfortable ride. Which is nice, since I would call the Fit's factory ride "extra firm". But your MPG will suffer a bit, and your tires will wear faster.
Raise the pressure by 6 lbs or so, and the car coasts easier, the steering is more responsive, and you MIGHT see an additional 1 or 2 mpg in city driving - maybe. But you'll feel it - and the added ride harshness isn't just bad for your butt - it's hard on the car. All those tiny solder points in your electronics are gonna feel each bump that much more. All those snap together plastic pieces of the interior are gonna vibrate more and start creaking and rattling that much sooner. It's just not a great idea for your car in the long run.
Manufacturers recommend tire pressures for a number of different reasons. Not all of them are for the best performance or mileage. Often it is for ride smoothness. In my case, the 36 psi gives even wear, better handling and good mileage. Good enough for me on both my Solstice and Fit. My CR-V gets lower pressure. Blindly following a car manufacturers numbers for everything does not always give the best results, from tire wear, mileage or engine life.
Oh... and I'm referring to Cold PSI, not after it's been driven for 10 minutes and then checked... there's a difference there.
In General...
33psi might not be the 100% best for the fit in terms of performance or economy but it's not going to be off by 10%. 33 for the Sport is going to be the best compromise of handling, economy, ride comfort, and most importantly, Safety. With lawyers chasing every ambulance, and every review targeting in on safety, automakers are very aware of what's best overall for the car (and the driver).
I've got a 3 year old in the back of my car and to think that there are alot of people out there with tires that are low (or high) and that they think they know more about what's best for their car than Honda does is a scary thought.
Everyone's an expert on everything they own and everyone is a great driver... Me, I'm an expert on knowing that Honda knows more than me about the Fit.
..and naturally, I think I know alot
~SB
I'm on my first set of tires on the Fit, and only 6400 miles, so it's too soon to tell. However, the recommended pressures on my previous car, a Subaru Forester, led to much more wear on the shoulders of the OEM tires, which were completely shot, and badly cupped at 25,000 miles. Upping the pressures 10% resulted in more even wear across the tread, less cupping, and ~40,000 miles per set. Cupped treads are very noisy.
My past experience has been with the cars listed in my sig plus my Parents VWs. (Bus, Vanagon, & Diesel Rabbit Pickup) I've only had one issue with treadwear on any of the cars and that was because of a bad Pressure gauge I had. The Gauge always ran about 5psi low so my tires were consistently 5psi high... (Had I only known...) Those tires were badly worn in the middle after not too long. Underinflated by a few lbs for a little while, then back up to normal, and got 40K miles out of them... I replaced them (and the Pressure gauge - It was the Acura branded Freebie that came in the glove Compartment kit with the free pen) and ran the factory PSI. No issues after that. I've run all vehicles at the Recommended Factory PSI (which has ranged from 32-34) and have never had anything other than even tire wear. I also Inflate the Ridgeline when towing or loading up the bed with heavy stuff. On average, I've run between 40K & 60K depending on the vehicle and tire.
~SB
~SB
I am astounded at how intollerant some on this forum are for anyone who has an opinion different from their own. Some are seemingly personally vested in getting everyone to adhere like robots to Honda's specs, from tire pressure to oil change intervals. There are actually people out in the world who can think for themselves, and have enough experience to make their own decisions based on their own knowledge and needs. They do not need Honda's permission or permission from anyone else. They have no idea what I drive, how, what my tires are or what my experience has been, yet they seem obsessed with getting myself and others to toe their line of thinking. To each his own. You do it your way, and I will do it mine. They are, after all, my cars, my tires, my engines and my oil.
They are your tires, your engine, your oil... It's my Child in the back seat of the car next to yours so my voice ends up being louder than many might like. Everyone's opinion is there own and as I said before, My opinion is that Honda knows more about the Fit, Toyota knows more about the Yaris, and both of them know about the tires that go on their car than 99.99% of drivers.
~SB
I agree with you 100%, just look at what was done to me at the beginning of my thread, I'm 63 years old and have been playing with cars since I was 17, building engines, autocrossing, you name it, I have done it. I've bought at least 15 sets of new tires in all the cars i've had and from my own experience I can tell you the factory tire pressure doesn't work 100%, specially when they want you to inflate the rear which has very little weight the same as the front which has all the weight of the engine and transaxle, I always overinflate the front by a few pounds and underinflate the rear by a few pounds and rotate every 7500 miles, in the Fit's case they want you to rotate when you change the oil which is OK by me, but the important thing is to rotate to get the best wear out of your tires. By the end of all my tires life they are worn evenly from edge to edge.
There is a saying that goes like this:Experience is the most useless thing there is because you can't give it to anybody else, you can only use it yourself.
#32
Miamifit...I wonder, with these posters who are obsesssed with Honda specs, how many of them have non-Honda wheels. Were they approved by Honda? Made by Honda? If not, they should not, by their own statements, be on their Hondas. How many have after-market lights, lightbulbs, steering wheel covers or pedal covers. Were they approved by Honda engineers? Made and supervised by Honda? I doubt it. That would, by their statments, make them a hazard to themselves, their children and the public. If not approved by Honda engineers, all these and any other aftermarket items should not be used as they are not per Honda specs. Yet they presume to tell others that they must adhere to Honda specs for such things as tire pressures and oil change intervals. Interesting people.
#33
~SB
PS. my Bell thermometer, V1, & Parrot Bluetooth aren't Honda Tested... Not sure about the Graco.
#35
You're 0 for 2.
Pop Mechanics on too stiff Fits. conclusion: myth
Consumer reports on tire wear. conclusion: follow manufacturers' recommended tire pressures.
You got a cite for a valid study or just opinion?
Here are excerpts: Pop Mechanics
Consumer Reports:
P.S. cheap insurance for a statistically non-existent event is 100% overpriced.
P.P.S. I've got some magnets I'll sell you. Cheap.
To invoke the MythBusters, we’d now consider the myth of increased fuel economy from over-inflated tires officially busted. So why didn’t the harder tires with less drag result in better mileage? Well, you’ve got to figure that, at 70 mph or so, the aerodynamic drag of the car’s body is probably outweighing the small improvements the tires gave us.
And we wouldn’t recommend anyone try this one at home either. The vehicle’s handling is compromised when the tires are over-inflated. At 45 psi, the ride was brittle. In fact, the tires were so stiff they nearly vibrated our garage-door opener right off the sun visor. Ouch. –Ben Stewart
too little pressure will overheat leading to failure, poor handling, and quick wear. Conversely, too high a pressure and the tires will ride stiffly, grip less, and, again, wear out prematurely. Low pressure usually results in fast shoulder wear; high pressure can result in fast center wear. Proper pressure delivers even tread contact to the road, balanced wear and optimum grip. It’s best to stick with the recommendation for the vehicle, as it’s designed to provide the best balance of longevity, ride and handling, and all-around grip.
#37
here is the way I read it...
This just tells me that at highway speeds, over inflated tires do nothing for gas mileage. That makes sense. If, however, you do a lot of city driving - you would think that the extra stiffness would give better gas mileage. How much? I don't know.
This topic comes up every now and then, and there are some who are passionate about only inflating to Honda specs. I have always inflated 5 lbs over max and have never, ever had un-even tire wear on all the cars I have owned. That's me. You do what you want. Would I follow the same 5 lbs over if I drove somewhere else with different driving conditions? Probably not. You have to determine for yourself what is best based on your driving conditions. If you don't want to mess around with anything, just use the recommended pressure. You can't go wrong that way....
#38
~SB
#39
BMW 1100 cc motorcycles are notorious for having very soft rims, and standard procedure to reduce the risk of destroying a wheel on a pothole is to run 5-10 psi over recommended. Interestingly, over time BMW's recommended inflation pressures for newer models (still essentially the same weight and tire sizes) has crept up.
Between Honda's recommendation and the max limit of the tire, it's pretty much an individual choice, without any significant impact on safety. Tread wear may vary, and only experimentation over multiple sets of tires can determine the "best" pressure.
This is turning into an oil thread, with very little likelihood of changing anyone's mind, but at least we can keep it civil.
