Question for you young whipper snappers
If you got a virus through limewire, you are likely just as susceptible through standard day-to-day activity. Limewire is one of many, many vehicles malware can leverage. For the most part, a very basic and general background can help you with all of these vehicles, rather than thinking you are safe simply because you don't use one program.
A lot of virus protection is common sense... Hmmm should I click the link or not?
~SB
Help?
Right. The problem was after downloading many converters who claimed to convert KOZ files - none worked. After some investigating, I found out the KOZ files are the same as ACC, and found an easy and free converter. I tried doing one song first and was able to get it to iTunes, so we should be good.
I'm about 50% of the way through converting all the songs.
Hi, Ihave the same exact problem and have not been able to find a solution. What free software did you find that works? None of the ones I tried will even recognize the file type. Thanks!
Thankfully I only had about 70 songs and not 100's or 1000's and the iPod came with a $50 iTunes card.
I believe it was called File Factory or something like that but it didn't work too well. It wouldn't read all the songs and the ones that it did successfully convert, when playing the songs on the iPod, they would either skip and/or speed up and slow down; so I just started rebuilding my list from scratch.
DeeJayK
2nd Generation GE8 Specific Fit I.C.E. Sub-Forum
11-21-2013 10:22 AM
