Can't open hood
Can't open hood
So I was upgrading my horn and I had to move the hood release cable out of the way, and I thought I put it back in place, but when I tried to open the hood this morning the interior hood release lever pulled all the way back without tension. I tried tugging on the cable and fiddling with the latch release under the hood, but I can't open the hood. Any tips? Thanks.
Good Luck,
-macbuddy-
PS-This will only work if you did not disconnect the cable from the release mechanism under the hood.
This is going to get expensive. I can see the grille being ripped out to get at it but then you wanted a new one.
Oh why did you remove the cable? None of the DIY threads said to do this.
Good luck.
Good luck.
You didn't mention what year Fit you had. Does this help?
Download PDF Honda Jazz Fit Service Manual | PDFTown.com
