Why there are no manual fits out there...
#141
I'm sorry but the torque converter does not double torque. It also does not magically create torque. You get a loss in speed whenever you increase torque, just like changing gears.
Dyno any MT vehicle against its AT counterpart and the MT will have a higher wheel horsepower rating. This is all old and simple physics.
The EPA rating is higher for the AT because the AT is geared taller, meaning the engine speed is lower for any given vehicle speed, thus spewing less emissions.
#142
From Wikipedia:
"The classic three element torque converter has an efficiency curve that resembles an inverted "U": zero efficiency at stall, generally increasing efficiency during the acceleration phase and low efficiency in the coupling phase. The loss of efficiency as the converter enters the coupling phase is a result of the turbulence and fluid flow interference generated by the stator, and as previously mentioned, is commonly overcome by mounting the stator on a one-way clutch. Even with the benefit of the one-way stator clutch, a converter cannot achieve the same level of efficiency in the coupling phase as an equivalently sized fluid coupling. In automotive applications, where steady improvements in fuel economy have been mandated by market forces and government edict, the nearly universal use of a lock-up clutch has helped to eliminate the converter from the efficiency equation during cruising operation."
Not trying to crash your thread, not saying AT is superior, just saying MT guys need to give the AT concept a lot more respect. Maybe if they didn't talk shit on AT drivers so much those people would consider going to the other side and you wouldn't have this situation where they are going away.
#143
The automatics are far better than they ever have been, with paddle shifters you do have much better control..... The torque converter and the ability to start off in 2nd gear makes for less slipping on ice or loose surfaces..... The biggest draw back I can see is the parasitic drain of power that is used to operate them on cars that have a relatively small amount of power to begin with.... I am thinking that there will be advances in CVT drive units in the near future that will even be used to maintain constant RPM operation of alternators, water pumps, air conditioners, power steering units, and the car itself.....The traction drive planetary unit used on Rotrex super chargers is an example and there are already cars operating in Europe with the type of system and I believe it has been used on on of the Saturn models over here..... The first example of this type of drive system was introduced as the NuVinci bicycle rear hub and it has been and is being tested for use in lots of different types of vehicles by manufacturers world wide.
#144
I think this will all be rendered irrelevant in the coming years by direct drive electric motors. Funniest Leno bit to date.
What ever happened to manual spark advance?
#145
Advance weights and vacuum advance followed by hall sensor monitors and solid state ignitions....There were still dash mounted units for manual use until the ECU systems started thinking it knew better than the owner driving the car what timing settings were best.... The last vehicle I rode that came with manual advance was an early 60s Harley-Davidson Sportster that had one controlled by a twist grip on the left side of the handlebar that actuated a cable to the magneto...... Retarding the ignition was a must if you didn't want to be launched over the handle bars while starting it and it could be retarded while decelerating after dropping into a lower gear to make some of the wildest backfiring sounds complete with flames exiting the exhaust..... The same bike also had an adjustable main jet needle that could be adjusted while riding.
#146
Say you are driving and your lover decides to give you some oral pleasure, the automatic driver is like "yeah baby" while the manual driver is like "hun there is a turn coming up... i need to downshift."
#147
An experienced driver would have the good sense to continue going straight until he or she had reached the maximum degree of pleasure and then make a U turn... It isn't a difficult situation to remedy.
#149
Obviously, you didn't pay enough attention to those films they showed in driver's ed: "Remember, when you're in a car, use your head-don't give it!"
#153
You ma have noticed that getting a 2010 Fit sport Manual is pretty impossible right now. Two dealers told me this week Honda pretty much cut allocations of them for the US down to ZERO. When I asked why, they both said Honda didn't feel there would be a market as VSA is not available with manuals currently. Both said the 09 Sport Manual with Navi models flew off the lots when the 2010's showed up. There is ONE 2010 manual in the entire state of California right now.... the lots are FILLED with automatics. Seems like a blunder of immense proportions on Honda's part to ditch that model. I mean, a stripped toyota YARIS comes with stability control standard for Pete's sake.
#156
Last year we had to order Fit Sports with MT and Navi. There weren't any in the US on dealer lots. Dealers all over the midwest advertised them in their inventories, but they were phantom cars. Honda apparently built the whole batch on two days in November of 2008. See this thread: https://www.fitfreak.net/forums/2nd-...uild-date.html
It took until the middle of January to receive the car. It was a great night to try out the VSA on the way home.
15,000 miles later (and all over the USA), no regrets. Tried the auto. Always shifting to a lower gear in cruise control. Never could get the idea of an auto in a little car.
Cheers.
Cheers.
#157
How about showing a little respect. Now I know why I don't come here anymore. And i paid MSRP just like you did in OCT 06
#158
Thanks Prick. way to take things out of context. We don't order vehicle based on what vehicle need more service. And I don't lie to make a living. And I don't give a Shit if your Fit is faster. FUCK YOU
#159
I simply offer some insight into the production schedule and point out that service cost does not factor into sales dept orders and he states that I "lie to make a living" and "don't care about the service dept"
#160
Here the MT GE8 is more then $1100 cheaper then the exact same GE8 with automatic. And its clearly better in performance too. According to the official honda website its faster, lighter and it definately has better fuel economy regardless of what EPA says.
I wouldn't even get an automatic if it was the same price as the MT. And I can personally vouch for how much fun a MT really is. I really enjoy shifting to the next gear, trying to rev match it and then letting go of the clutch. Trying to get the instant and smooth transition each time is so addictive. I highly recommend getting a MT. This really sounds cliche but its the truth.
Probably the only time I would buy an automatic is when I buy a hybrid or a single speed electrical car. But now MT offers so much more its is cheaper to boot. I drive in heavy traffic sometimes too and its really not hard at all. And you dont have to do anything at all once you are in the 5th gear. Its not like you constantly have to operate the knob and clutch. But trust me you'll want to shift all day anyway.
And for turns or traffic lights. I just pop it in neutral, take the turn, then select the right gear, rev match it and start shifting again. I use engine braking alot too to control my speeds while preserving my brakes and fuel economy. Its just too much fun.
The manual shift boot looks alot better then the automatic too. The stock manual shift knob makes the jazz look luxurious while I think the automatic looks ugly. Well I just dont see any reason to get an automatic. None at all. Except maybe in mountains.
