Rear window & my salesman was kidnapped!
Two part question / story here.
I'll start with a question about my rear window. I keep the car spotless and it looks as good as when it was on the showroom floor including the glass. I have no problem looking out the rear window through my rearview mirror during the day but at night the window it looks foggy. I've tried using the defroster, making sure the "high beam switch thingee" on the mirror is in the right position and cleaning the window. Is there something applied to the window that I don't know about?
And in regards to my kidnapped salesman. Yes, I meant it. I came across this story on CNN. He apparently took somebody out for a test ride in an Accord and the driver refused to turn around. The guy ended up getting arrested in Wisconsin (the dealership is in Massachusetts).
The salesman was let go about 50 miles away from his work.
Car salesman kidnapped off lot | WWLP.com
You may be seeing the results of the plastics in the car out-gassing. New cars usually have this issue, it collects as a haze on the glass. I have to wipe the inside of all my windows a couple times a month because of this.
Out-Gassing of Plastics
honda_fit_2009
01-04-2019 05:01 PM
CoryBoyUSA
05-31-2009 12:00 AM
