Road Noise
Road Noise
Does anyone not hear their A/T engine reving up when accelerating more than they should. Maybe I have had the luck of Accords before and the inside cabin is quiet and smooth but I really can hear the reving up clearly inside the cabin of my Fit. Before I start to think that somehow my dash isn't screwed down tight enough, how prevalent is your road noise. I keep my stereo on at least at a 12 level just so I don't hear my acceleration.
i can hear it nicely when i hit about 4k. I actually like the engine noise. You get to hear the engine pumping out all 117 horsies. I mean, when you think of it, half the engine is under the dash. Why wouldnt you hear it?
I too went from an Accord ('07 V6 EX-L) to the '09 Fit Sport and the road noise (or engine noise) is very noticeable.
My logic on this is simple: it's not the $28K car that the Accord was. My Fit was like $17.4K.
You could probably consider using some sort of sound dampening material in order to suppress some of the noise. You could do the following:
1. Use several layers of Dynamat (or similar) materials as a hood liner.
2. Access the firewall to the car and apply further amounts of sound dampening material.
The above may work but I have not read any posts specifically in support. The added weight of sound deadener materials (although minimal) may effect MPG efficiency. Just a thought.
If you end up doing such a thing as I described, please respond to the thread so you can comment on the effectiveness as I'm sure myself and others would be interested to hear.
Its an econo car (which means very little insulation to keep weight down)and the engine is a lot closer to the cabin (thus the short hood). The back part of the engine is practically right under the dash. Just turn the radio up a little more.
