Honda OEM armrest questions
Old 08-20-2009, 09:21 AM
fmcfad01's Avatar
If this wasn't posted before, here are the install instructions:
http://techinfo.honda.com/rjanisis/pubs/AI/AII39836.pdf
Old 08-20-2009, 09:41 AM
Selden's Avatar
Thanks for photos from different angles. Do you find that the center console interferes at all with the parking brake -- or only when it's in its forward most position? Is it higher, lower, or the same height as the OEM driver's side armrest on an 09 Sport?
Old 08-20-2009, 05:58 PM
FitStir's Avatar
I think most people are used to pulling the parking brake straight up, installing the center console will not make that too easy, unless you want to fold up the console each time. It took a little getting used to pulling the brake from the side, but now it's second nature, I wouldn't think it would be a problem for anyone to get used to.
I think the console is a little bit lower than the original little armrest. I can't recall exactly I'll check next time, and post pics whenever I can.
After driving with it on for a while I would not want to go back to that little armrest. It's extremely comfortable, especially with the additional padding on the cover. I highly recommend it. It's a little expensive, but I think it's well worth the price, since I use it each time I drive, and it's official Honda.
Old 08-20-2009, 07:34 PM
Selden's Avatar
Thank you -- this information is very helpful.
polokid69
09-05-2012 06:35 PM
obd1integ
04-11-2012 09:44 PM
2Fit2
06-23-2011 07:34 PM
Java^FiT
01-11-2011 12:58 AM
diskullman
12-30-2008 02:40 PM
Quick Reply: Honda OEM armrest questions
