Cabin filter location?
I was just wondering if the cabin filter is located in the same place as the GD's?
Shown Here: https://www.fitfreak.net/forums/fit-...placement.html
Also is the fuel filter located in the gas tank as well on the GE8?
Thanks
Thanks
Are you sure about the fuel filter? While installing my PRM intake (AT), There is what looks to be a fuel filter on the diver's side of the engine bay toward the back, above the transmission, under the factory airbox. I haven't looked it up so I may be wrong and if I am, are you able to tell what I'm refering to is?
Does the GE's use the same cabin air filter as the GD's. If so I can get them allot cheaper through FIT cabin air filter for a 2008 HONDA $7.1 then what the dealership is charging. They are quality filters as I use the same brand in my Tacoma.
I looked up the part #'s at bernardiparts.com and they are different for the GD & GE8.
Freak In A Fit
02-14-2011 01:07 AM
