Another offset question... with spice!
Advan RGII in 17x7.5, 4x100, 41 offset, 215/40R17 Tires
Will this poke?
I have seen Volks, with a 43mm offset with the same above specs, fit close to flush when lowered on T1R's. I'm not sure if they needed to play with the camber though.
Here's the Advan's on the AJR GD.
Aaand the spice
Will this poke?
Aaand the spice
I don't know, but this just made me laugh. Thanks. Good luck finding out that information.
you will rub, but prob not bad. I rub on big dips and bumps with 205's and +43s
and there is nothing wrong with poke as long as you can get it to tuck on compression. I plan to space mine out some once some decent coilovers hit the US market.
mikeGe82012
05-28-2017 12:11 AM
