What is this?
Location: Winthrop Harbor Illinois/ Presque Isle Wisconsin
every car I have ever had has a serial number stamped on the firewall or a serial number plate.
Since the Fit has such a plastic and sheet metal shrouded firewall they give you an access panel. So it it what it says. Never shined a flashlight in there cause I am 98% sure this is correct.
I figured it would be self-explanatory. But the frame number is located behind that panel. If you are looking for it, you found it. Other than that, the compartment does not have another purpose. Unless you want to hide some "stuff" for your "friend". LOL
And I should know this because I had that whole cowling apart when I changed springs. But being ADHD I concentrated with tunnel vision on the springs and i FORGOT to check that,
I noticed that gap yesterday whilst cleaning the windscreen. Probably there because of flexing of the cowl/front end. Plastic being more brittle than steel, the put the gap in to prevent the plastic from shattering. Looks a bit daff, though!
