^o^ D.I.Y Vertically @ rear wiper :: FIT & JAZZ :: GE
^o^ Photos for verticallizationing of rear wiper for
:: FIT & JAZZ :: GE
1 & 2)All E round in red is the clips 1,2,3,4,5,6 & etc ....
2)after u pull of the black cover u should see
ur wiper dinamo , remove the three bolt round in red ,
the wire cable & holding the wiper compartment on ur car
3)now u already remove the dimano
there's 4 bolt holding this cover round in red
4)now this is what u should see,
there should be 6 hole on it
5)u should get this result
move the arm backward
& now put the metal bar back
than install everything back
hv fun ^o^
:: FIT & JAZZ :: GE
hv fun ^o^
I know why the Japanese guys do this.... but in the states where the wheel is on the other side of the car..???? ( The Japaneses guys do this mod so that they have a tad bit more visibility out the back window when backing up.... well most of them anyways )
Thanks for the cut and paste... I'm sure some ....will find this helpful
This would also be usefull in places where there is much snow, like where I live. When the wiper rest in horizontal position it collect snow and ice and finaly the wiper will wear away.
I was looking for a way to do this, but I have now desided to remove the wiper totaly and replace the panel with a panel that is badgeless and without hole for wiper (from i-Kona).
Sir,
Do you actually have to pull out the rear wiper first before doing step 1?
And what happen after the last step? (switched to the left-most hole on the white spur gear)
After put everything back on and should we just turn the wiper on?
If we do, will the wiper reposition itself automatically (like when you try to shut off the wiper halfway to its complete cycle)?
Thanks for the help sir
JUSTinSANE671
08-31-2011 11:08 PM
dg748
06-20-2009 06:28 AM
dg748
06-20-2009 06:23 AM
dg748
03-16-2009 09:21 AM
