While driving my windows rattle like hell while opened a couple inches, even with the felt tabs they give u to prevent that noise.
They look cool tho!
Front Lip
Did the DIY garage seal front lip. In combination with the CRZ undertray my average MPG figure has gone to 36.9. It started at 33.2. Was 35.7 with the undertray only. I'm pretty happy with the results. Want more lip!
The lip is go!
The lip is go!
just from Mopac no brides at the moment.
Right now, if I get a flat tire (which I am prone to do when the tires wear down for some reason), I can move the wheels around and put the donut on the rear. And that's because the front have those bigger brakes.
I still haven't done it, but I think I have all the parts to replace the rear drum brakes with disk brakes... the problem is, they use the same 12" size rotors as the front, meaning I would need 17" wheels to fit over them too. And I won't be able to use the OE donut.
And thanks for pointing this out. I have not considered that my spare won't fit on the front discs and maybe not the back discs. My rear rotors are small, off a 2000 insight, but the spare wheel may not clear the caliper. Maybe a full size spare on a steel wheel for when I travel...
this is not what i did to my GE Fit today, this is what i've been doing to my GE Fit for the last two weeks. i finished painting the rotors. i made it way more of a hassle than it needed to be. more on that below. before and after pics too.
while i had the wheels and rotors off i hammered the inner fender walls to stop the tires from rubbing. the tires still rub the plastic fender liner, but not for long as the plastic fender liner is wearing away.
back to my rotor painting screwup. i painted the entire rotor including the friction surface where the pads contact the rotor. this is a recommended method in many of the DIY videos. but i made a big mistake by trying to do a great job (try hard) when i cured the rotors per instructions from VHT, 200 degrees for 1 hour. the curing/baking did a great job of making the paint rock hard, but then the pads were sliding on the paint until it began to melt and when i came to a stop the paint would cool and the pads were locked on the rotors. it became a gooey, sticky mess. so i had to remove the rotors again, wire brush the heck out of them and start over. what a hassle. this time i cut some cardboard to protect the friction surface, repainted the rotors then cured the paint on the car using the braking heat. any uncured paint is easily peeled away by the pads.
Front Rotor Before
Front Rotor After
Rear Wheel Before
Rear Wheel After
Rear Rotor Before
Rear Rotor After
Front Wheel After
all's well that ends well. the black rotors are a huge improvement over the rusty look. oh, and i replaced the chrome lug nuts with black spline tuner lug nuts.
Front Rotor Before
Front Rotor After
Rear Wheel Before
Rear Wheel After
Rear Rotor Before
Rear Rotor After
Front Wheel After
Got any more pictures?
No, those are not the fastbrakes conversion. The rotors are from a 2nd gen special edition insight sourced from the UK and the calipers are from a '98 integra GSR. With the rear brakes doing so little in terms of braking power, there is really no need to do discs. We did it on this car because we were trying to imagine how Honda would have / should have done a Fit Si.
Did an oil change… still had to change the oil for the super charger and rotate the tires when my sister called me to go eat at our other sister’s place.
Decided to button things back up.
I didn’t crack open the supercharger, so I didn’t have to do anything for that. But I did loosen the lug nuts for the front wheels, so I had to tighten those back up… just as I was tightening the driver’s side, the wheel dropped (an inch or two?).
I’m like, did the wheel fall off the center hub? No…
Did the CV axle pop out? Hmmm… no…
What then? Took a look… top of the strut was no longer attached to the car. Apparently the center of the top rubber grommet separated from the rest, dropping the strut.
Forcing me to hijack my HR-V back from my siblings, until I can get the replacement parts.
So I’m back! Had a 2013 Fit Sport in TW manual more than two years back. Young and yearning for the experience, I sold the Fit and got a 2019 Si. Owned the Si for two years and sold it three months ago for a decent offer I couldnt resist. I reached out to the current owner of my last Fit but he said he has no interested in selling the car. It sucks, but now I’m back in a 2013 Fit Sport in Polished Metal Metallic manual, I’m sure I overpaid in the current market conditions but if you want it get it kinda thing.
Anyways, the Fit has 76k miles and the brakes must have been replaced sometime in between by the past owner but I went ahead and changed them to EBC Green stuff pads and new rotors. Also changed the oil and filter.
The swift springs I had in the TW Fit were soft with stock suspension as I remembered. Up next will definitely be suspension + rsb, coilovers recommendations, anyone (for a daily)?
