Fuel mileage. People report an increase on the highway. Reason enough for me. That gaping hole under the engine bothered me. It has mounting points as if something was supposed to go there. Now something does. I'm hoping to get 35mpg combined once I do the front lip thing. Thinking about doing side skirts as well.
Keep us updated!
Picked up my first Fit today and gave it a bath. It's an 09 Sport with a manual transmission.
Got a decent deal on it, maybe for good reason as the clutch is acting funky, probably air in the lines. Trying to find a shop to fix it and get it on the road.
Plans are to baseline the maintenance, install an UltraGuage, SRI, exhaust, and lower it a hair then drive it.
I have two goals...maximim handling with stock shocks/struts and maximum fuel mileage as I put a lot of miles down.
New side marker LED bulbs. They're nice! Replaced brake light bulbs. Broke off the locking piece for the panel in the footwell. How am I supposed to open and close this thing properly? I just couldn't get it to go back. And, know where to get a new locking piece?
The First Fit expired due to an unfortunate highway incident involving nearly worn out tires, standing water, a strong crosswind, and a subtle curve at night.
Fit #2 I've been trying to make like the other one. The other day I installed a Progress RSB, Godspeed springs, Honda "crash" bolts, Buddy Club extended ball joints, and had already had Enkei RPF1 wheels and Toyo Extensa HP II tires put on it. I'm probably going to do a Cusco front strut bar soon as well. This car is a bit more solid than the last, but has a lot of minor cosmetic damage as well as plenty of real mechanical woes.
There was a clearance issue with the leading edge of the control and arm and wheels, which I clearanced the control arm slightly to take care of.
I had Swift springs before. These are 20% stiffer up front and 25% stiffer in the rear. The fronts are straight rate and the rear progressive. It actually works really well. The car rides flatter and the rear doesn't skip off pavement imperfections mid corner like it did with the Swifts. I would've liked to have tried the Progress springs, but they were discontinued.
I had also already repacked and rebooted a CV axle, replaced a hub and wheel bearing, replaced the factory cross brace which was bent, replaced a brake caliper that stripped out (threads rusted out), replaced a broken speed sensor, replaced a missing hood air duct, and did braided brake lines.
I have just purchased a K&N filter, am going to do a DIY front lip, need to figure out why the AC quit, am replacing a bad sway bar link, and have a CRZ under tray to install. I'm also waiting for a set of Innovative engine mounts.
The car has a broken transmission case at the flywheel/clutch case which I didn't notice until the first time I jacked it up. That was disappointing to say the least. At some point I may buy a used case to LSD or may K swap. Dunno. I will make a patch plate in the meantime.
Dirty cowl
Sprangs
"Crash" bolts
Rear spring
Assembled strut
Extendo joint
Ouch
Chop chop
Dirty cowl
Sprangs
"Crash" bolts
Rear spring
Assembled strut
Extendo joint
Ouch
Chop chop
I installed innovative mounts all around and the car responds much better to acceleration, but IMHO the cabin noise is defeaning and not worth it unless your pushing 180+ hp. You will lose a lot of comfort from installing those mounts.
Great job otherwise on the upgrades! Kick ass man
Wait a minute. This looks a lot like the Fit that TCS just finished swapping with a K24. Is that you?
oh man! That's excellent. I've been wanting to see videos of this thing in action and get to know how you like it. From the little I've seen from following TCS on this build, it seems so thorough with A/C and stuff!
I understand that there's going to be some article of some sorts on this build soon?
The good news: The car is a beast. My only complaint about the power is there's so much torque available everywhere I am getting lazy about shifting. Just hit the gas and go. Not like the old days of VTEC scream. The grip is vicious coming out of a corner and the FWD power ferociously claws the car back on track with almost no driver intervention (unless traction control is off). And one of the best things about the car are the 9th gen civic si seats. The guys at TCS did a great job on them and charged me accordingly . Also, as best I can gather this is one of the few K24 swapped Fits that has functional cruise control (a must have to keep the wife happy and let me spend the $$$ to have this done).
What LED did you use?
I've busted my panel too. The tiwst clip on the left side is what breaks. I went to a junkyard and pulled one out, you just need super strong fingers or a pair of pliers to pinch it from the underside and it will fall out. Then just pop it in yours.
I don't normally post on here, but I figured I should as I'm really happy to see so many people tinkering with Fit's now. Adding one more K swapped GE to the world. We didn't tackle AC yet, I just wanted to drive it for the summer and worry about that later.
K24Z7
AEM short ram
RBC intake manifold (ported and polished)
PRL adapter and thermal gasket
J35 Accord throttle body
Flashpro
Result = equal speed with a stock mk7 GTI from a roll with one passenger in the Fit
Threw in Morimoto LED fogs and IPF LED headlight bulbs
K24Z7
AEM short ram
Flashpro
K24Z7
AEM short ram
Flashpro
K24Z7
AEM short ram
Flashpro
There is a company out there now called 2nrs that makes jumper kits from a TSX harness to the Fit with a k24z7/z3 for the motor but also for AC. You still need a TSX compressor and a stepper motor (?) to make it work though. I wish this was an option for me when I was gathering parts instead of going custom.
New Head Lamps
Intalled GTR CSP Mini H4s. Could've used the more powerful (more lumens) GTR Ultra or the Morimoto 2Stroke 3.0. I decided the less lumens would:
- not distract other drivers as much
- save me some coin, but I would have liked the Ultra lifetime warranty
- the CSP Minis are exact replacements, no heat sink, fan or additional cable
- make me less likely to be pulled over for aftermarket headlamps
