No I haven't had the time to try and fix them or debate myself on whether it is worth it or not yet.
might want to consider replacing that tire as the chunk looks pretty close to half the sidewall thickness...blowouts can have extreme consequences.
a flat metal file will smooth the rim in a quick minute
Ordered new window weather stripping, grille, valve cover gasket, new konig heliums and tires today. Going to sell my old wheels and tires and from that buy coils and rain guards. Should be fresh going into 2020
List My Used Ohlins Springs (made by Eibach from their Eibach Racing Springs ERS Series) that was part of my JDM Honda Fit GE Ohlins Coilover Kit on Fitfreak For Sale forum today for just $168 per set including shipping
Below is the link:
https://www.fitfreak.net/forums/2nd-...ml#post1440532
Below is the link:
Installed a new Sprint Booster V3 today.
'Wow'...I wish I would have done this when I bought the car!
Shifting was never as much fun before. Downshifting/rev-matching...the rpm's don't hang...no lag.
So much better now.
So much better now.
It was technically yesterday (Saturday), but I finally used my Fit for work again.
My father, being a bit of a busy body, made us work on my Fit the day before (Friday). I think I mentioned this before, the parking brake basically gave up and it takes almost no effort to pull the handbrake all the way up. So we worked on the rear brakes (still drum for now). The driver side brake's "automatic" adjuster was seized while the passenger side had the metal piece pulled by a spring that's supposed to move the adjuster, skip and go past the teeth on the adjuster. In short, BOTH sides failed.
Once I got the driver side adjuster out, my dad twisted and greased it until it move fairly smoothly. I don't know how smooth its supposed to be, but it was definitely smoother than when I installed it (yes, I used the supplied grease at that time too). Total pain in the ass to put back in. Of course the other side was simply tugging the piece back in place.
With that done, it feels a lot more like it did before, increasing tension as I go up.
Unfortunately, the front suspension seems to be loose somewhere. I get clunking when going over larger dips and sometimes when moving after switching directions between reverse and forward & vice versa.
Got a set of Yokohama Avid touring tires in 195-60-R15 to go on. Walmart was selling them for almost 30 dollars a tire cheaper than anyone else, just waiting for them to get here along with new lug nuts and hubcentric rings.
EDIT:. and speaking of cheap these wheels sell for $100 everywhere except Amazon, who wanted $82. Got the deal of the century I reckon. I'm looking to sell my old wheels and tires after install to recoup most of my money.
those wheels going to look sweet especially with the rear disks! be sure to post pics.im curious the tire should look nice n meaty. maybe i missed it, but what offset did u go with? and did u dismiss a 205/50 or 55 for any particular reason?
nice wheel choice. one of the wheels i was considering for mine.
The other reason was comfort. My commute is now mostly freeway, I wanted a little more sidewall for a little more comfort.
I'm running I think 37mm offset compared to whatever the stock is (50? 55?) But the end result is the car track will be 22mm wider and should fill out the wheel wells a little better.
This
nice. thanks for the vid...watched a bit of it and plan to finish it after work.
personally i hate buying wheels and tires. too many things to balance and consider. color, diameter, offset, width, weight, strength, fitment, appearance, performance, tire life, tire aspect ratio, tire width, price, etc. so many compromises with the whole process, lol.
i do prefer the chubby tire look myself. not sure if i want to lean mine towards aspect ratio vs width.
excited to see how yours comes out though!
Well, today was great... along with the crappy LED turn signal bulb that didn't work yesterday and most of tonight (for some reason, it started working again on my way home...?!?), I found out that my supercharger sprung a leak, again.
Looks like I'm benching my Fit from any driving until I decide what to do with the supercharger: have it fixed/rebuilt (last time was $1k), buy a replacement ($2500) or revert to stock intake manifold. With either of the first two options, I'll need to add the pressure relief valve that I didn't add during the previous rebuild.
