Old 04-08-2016, 06:38 PM
counterFIT's Avatar
Replaced my sway bar end-links today with Moog K750381 end-links. The knocking was annoying as hell, but what I didn't realize is how much performance was dampened by the bad end-links. The car handles much better now and bumps aren't anywhere near as bumpy as they were before. And of course, the knocking/thumping is gone
  #15222
Old 04-08-2016, 11:29 PM
connor55's Avatar
What was wrong with the stock ones?
  #15223
Old 04-09-2016, 12:43 AM
The rubber boots probably perished.
Happened on my GD around 75k miles.
  #15224
Old 04-09-2016, 01:05 PM
counterFIT's Avatar
Yeah that and the bearings are probably bad as well. The Moog links have grease fittings as well, so they should last quite awhile.
  #15225
Old 04-09-2016, 08:54 PM
FamilyWagon's Avatar
Who drives the white Mugen Fit I think on white wheels in NORTHERN VA?....
  #15226
Old 04-09-2016, 11:03 PM
counterFIT's Avatar
Got new front tires today... And although the end-links helped with the knocking, it was still there... The culprit? Driver's side strut mount. It was pretty loose, so I tightened the hell out of it. Noise gone, handling improved.
  #15227
Old 04-11-2016, 12:45 AM
Mr.Hollow's Avatar
Got my resonator welded back on. The drone is now gone, and so its the deep exhaust note...but it's drivable now so that's worth it.
Ordered a front windshield banner, which will actually be functional. Somehow the sun always pokes in between the interior sun visors.
  #15228
Old 04-11-2016, 01:44 AM
Burzpaw's Avatar
Still has a pretty deep exhaust note by itself though, but yea def not as loud haha
  #15229
Old 04-11-2016, 11:13 AM
g95pteg's Avatar
Curious to see what you do.
This is one of my pet peeves on the fit.. have to arch to the left of or to the right so the sun gets blocked by the visor or else it hits that perfect spot to be annoying.. especially in my mornings driving in to work as the sun is rising
  #15230
Old 04-11-2016, 11:41 AM
sultanofslide's Avatar
I'm tall enough that the headliner is my visor. Thehe side windows are another story altogether, even with the visors out thevdo almost nothing for me.
  #15231
Old 04-11-2016, 12:35 PM
Fit Charlie's Avatar
Wraparound sunglasses.
  #15232
Old 04-11-2016, 01:10 PM
g95pteg's Avatar
The OEM window visors solved that issue for me quite well on the side.
I can use the headliner as a visor if i lean back.. but not comfortable either.. was looking at this
2009-2010 Honda Fit Windshield Tint Strip
  #15233
Old 04-11-2016, 06:16 PM
Burzpaw's Avatar
"Homemade" side skirt extensions-- planning to paint it with truck bed liner to raise up its durability. Might paint the new-ish sti lip that will go on later too.
Attached Thumbnails What did you do to your GE fit today?-26311375051_eaea7521c5_c.jpg   What did you do to your GE fit today?-26351694816_3611b7d02b_c.jpg
  #15234
Old 04-11-2016, 08:08 PM
g95pteg's Avatar
This is exactly what I want to do but haven't got to it.. What material did you use to make that and how do you plan to mount it?
Looks like the edge is tapered.. Is it done with a router?
I've been thinking of using pvc board for the sides.. And possibly rear
  #15235
Old 04-11-2016, 09:09 PM
BMW ALPINA's Avatar
Some parts and tools arrives today:
Drilling Bits to drill holes on the firewall and Rubber Grommet to protect the wiring from the sharp edges of the holes.
This holes will be where the Boomslang Wiring Harness, Defi Boost Gauge and Water Temp Harness pass from inside the cabin to the engine bay.
Few days ago, the ATI Adapter ring so the AEM 52mm UEGO gauge can fit perfectly into the Gauge Pod arrives along with the extra O-Ring for the Sprintex Intake Elbow:
Several shades of High Temp Black Paint and Primer to paint the Sprintex
Supercharger:
Tools to help with taking out the OEM Radiator and Breather Hoses so I can replace it with Yellow Samco Hoses
Plus Tools to do the VALVE Gap Adjustment:
3M 1080 CF12 Carbon Fiber Vinyl Wrap and the tools to apply it,
I am going to WRAP the ALL-FIT Rubber Lip below my front bumper
Last, the 3.5in diameter Dynomax Race Mini Bullet Muffler model 24249 with 2 piece of Summit Racing 3.5in to 2.25 in Adapter arrives too,
I am going to check the space later, and if I see there is enough space
for the larger 4in diameter 24250, I will get that instead and return this 24249...
Attached Thumbnails What did you do to your GE fit today?-80-img_0740_bbb447cfeb92fc430ed313ffd4272c22322b6017.jpg   What did you do to your GE fit today?-80-img_0741_7a6a9a399dd02adc48bf0c4273d396dbad28d571.jpg   What did you do to your GE fit today?-80-img_0734_06edb0ca2fc39f5efc067de991f43d2c0b61c0e5.jpg   What did you do to your GE fit today?-80-img_0742_d1c52d67808b2b807ac3c57878b59264817ba98f.jpg   What did you do to your GE fit today?-80-img_0757_38251796ccadea9ed66c0962bd48fd1cedbb97f1.jpg
What did you do to your GE fit today?-80-img_0755_241ba07345a8eda8a28e7db5f16a962b1cf4b112.jpg   What did you do to your GE fit today?-80-img_0756_26051f0dc8e8065d31bdcf71d56131da0f02bb6e.jpg   What did you do to your GE fit today?-80-img_0753_549d7b737ca8a9707eaee8b1f23684f90ff6269d.jpg   What did you do to your GE fit today?-80-img_0754_ff6396bf73005a9856b5c892c45f4c81d22d9763.jpg
  #15236
Old 04-11-2016, 09:54 PM
Burzpaw's Avatar
Not exactly homemade -- though someone could make it very easily haha. It's just base moulding from Home Depot, made out of wood. Ordered it online though because the shape isn't available at the stores. I picked the tapered edge to work with the front sti lip I have and so it has more flow to it than a basic square one would.
  #15237
Old 04-11-2016, 11:29 PM
GE8FTW's Avatar
Haven't been on here in a while but I have done some stuff to my car mugen grille JDP lip JDP duckbill
Attached Thumbnails What did you do to your GE fit today?-80-img_1503_7c7f443928a6cfbe6c85208224a83a27a59b07f8.jpg   What did you do to your GE fit today?-80-img_1503_e7892f19d84f1c4dea3ec5c30220b82e154fd371.jpg   What did you do to your GE fit today?-80-image1_6035788a43aef7e12348701fb4d59bc7c4a68ca8.jpg
  #15238
Old 04-12-2016, 12:00 AM
Mr.Hollow's Avatar
Z that looks really good! I didn't expect it to be made of wood. I have thought about some universal side skirt splitters (top1 motorsports). It would help with some of the cone rash during autoX lol.
I love that JDP lip for the bases, it should be on every base owners list. Also glad to know John is still cooking, I am thinking of picking up a duckbill soon. How was the mounting?
  #15239
Old 04-12-2016, 12:16 AM
Burzpaw's Avatar
Yep-- there's some mouldings made of vinyl but they costed more. I figured these would last me long enough. They're pretty light and hopefully the truck bed coating would help with any scraping but I don't think I'll scrape them much; my front lip takes the beating.
You should! Looks good too haha
  #15240
Old 04-12-2016, 12:46 AM
GE8FTW's Avatar
I love that JDP lip for the bases, it should be on every base owners list. Also glad to know John is still cooking, I am thinking of picking up a duckbill soon. How was the mounting?[/QUOTE]
Mounting was sketchy had to drill into the hatch but it all worked out it was worth it. John is a cool guy he had to make it for me took him three weeks well worth the wait.
Quick Reply: What did you do to your GE fit today?
