Offtopic but anyone know why the TPMS need to be reprogrammed everytime you switch tires? I spent a few hours the other day searching but couldn't find the actual answer.
Or is it that they need to be reprogrammed everytime you add a new TPMS but not when you just get new tires?
This is my first car with TPMS in awhile so I will admit I'm not the expert
Maybe because it was a hot day but when I installed my Injen CAI it was a major PITA, I cursed it a few times for sure that day
Like i said before, the ECU only holds one set of IDs.
Of you swap tires (summer/winter), but NOT sensors, you don't need to reprogram. But that can get costly if you want to swap wheels also, because you'll need to move the sensors if you don't want to reprogram the ECU. And if the tire isn't flexible enough, the tires will have to be unmounted, move sensors, then remounted. Double if both sets are too stiff.
If you bought the window visors new, check the inside of the box. I thought I was missing hardware until i found it hiding, taped to the inside of the box.
Yeah, I found the clips, they just sent too many of one and not enough of another. Short two clips to finish. Have the fronts in but the rears are in the back seat in the box still. The seller is sending out the two missing clips...but now I have to wait. :7
you cant use the stock driver side armrest in conjunction wit the add on right?
You need to reprogram only when swapping TPMS sensors.
Tire Pressure Monitoring System - TPMS
It needs the installer to have the programming software (with hardware to communicate with the sensor) or handheld unit... but I don't know how popular this is, if at all.
So, unless you know your installer has it.. might be easier to just go with the ATEQ quickset, since you can program in ANY TPMS sensor in the future. The "ez-sensor" might require an install charge for the programming... on top of the fact each sensor costs about , while I saw TPMS sensor as low as . TireRack charged me $36 each when I bought it with my tire and wheel combo.
~~~~~ on un-related news ~~~~~
Here's an updated pic of my dash with my trim piece around the navigation unit. I had to dig around my room to find the original trim that came with the unit. Then found that the top and bottom were too wide so I had to cut, trim and file it down a bit. The sides are a little too narrow, but fit better than the Metra trim piece. It doesn't look too bad in the camera pic. And if you don't stare at it, it looks fine. But doesn't stand up to any kind of inspection, since I had to hack it in. It would probably look better if I could set the whole unit with trim a little deeper into the dash piece, but there's no screw holes that would line up at that point.
Up close with unit booting up.
Too bad the TPMS doesn't give you actual readouts but that's another topic all together
I was going to say there weren't any programmable sensors... but apparently, there is, at least, one.
So, unless you know your installer has it.. might be easier to just go with the ATEQ quickset, since you can program in ANY TPMS sensor in the future. The "ez-sensor" might require an install charge for the programming... on top of the fact each sensor costs about $46 at Amazon, while I saw TPMS sensor as low as $18 @Amazon ("Genuine" Honda Part number 42753-SNA-A830). TireRack charged me $36 each when I bought it with my tire and wheel combo.
I would be in heaven if the TPMS put the actual tire pressure on the dash... that'd be so cool/useful. For me anyway. Do they have anything like that that doesn't require a sponsored race team to acquire? Probably no lol
Got it, so i'd have find someone with the programmer. You are right it would just be cheaper to get the quikset, it'd be a good tool to have in the toolbox anyway nowadays.
Absolutely stupid they require a dealership to do it with the Honda ECU tool.
there should be an on-board procedure to do it without a service call.
Then there's folks like me, replace the wheels once.
And since the Fit wasn't particularly targeted as a winter AWD vehicle, or a sports vehicle, I'm pretty sure those that do the summer/winter swap is in the minority.
So not sure if they can justify the cost.
That being said, i recall reading something about some vehicles that have TPMS that automatically relearn sensor IDs. I wonder how much those systems cost. Or rather, how much they affect the price of the car.
The unit itself (not sure if the sensors are included)MUGEN Electronic Parts 01 Type A Honda Civic FD1-3 06-11
Rakuten link ---> Mugen Infinite i-TCMS Life
Aside from the combined price (sensors, unit, etc, etc), I don't think you can use it with the OEM sensors... so it's either/or.
Also there was another company "Orange TPMS" which supposedly offers TPMS sensors that can be cloned, but when I tried to contact them via phone & email, I got no reply. Orange also makes a TPMS system similar to the Mugen where it displays tire pressures for motorcycles... possibly for cars too.
That is SUPER boss. After shipping it's ~$900 though. And that's for just the unit or does it include the sensors? Either way, after having them installed you're going to pay well over $1000 for something you can just check every week with a normal tire gauge. Not to mention just LOOKING at your tires to see if they are low. This is meant for racers so they can see their tire pressure on the fly out on the track. Not that you couldn't use it on your daily, but man that is some serious dough for such a tiny piece of equipment.
That is super cool, thanks so much for posting that.
That price is honestly not bad for something like that. I mean a STACK dash setup is like $1400+. I fully expected it to be more than $1k. I wouldn't run it on a DD of course, but it'd be super useful for a race car.
$1k for something that tells you your tire temp/pressure? That seems insane to me. You don't NEED a digital display of that all the time. Sure it would be nice to be able to see if the pressure in a tire is going down noticeably while driving so you can pull over before the tire goes totally flat and you maybe damage the tire or wheel, but are you going to be looking at that gauge every five seconds to watch for that happening? Also you might not be able to switch the units, in which case you're going to have to learn celsius to farenheit and atmospheres to psi conversions in your head. Like I said I think this is really meant for track use. If that's not what it's meant for then that's really where it would be most useful and worth the money (in my opinion). The Fit already has TPMS sensors so if one gets low while driving the light will come on. Then all you have to do is pull over and check the pressure in the tires unless one is visibly low.
Racecars are expensive. I'm talking about a legitimate competitive racecar, not a weekend warrior daily driver. $700 for something like this to monitor tire pressures real-time while out on track is nothing to a competitive race budget. $700 doesn't even cover tires. So why not just throw it on?
Edit to pozzi:
I'm not even a racecar driver and I can tell when my tires are off 2-3 psi
I just think it'd be a useful data point to have when you're setting up. People on here pay $600 for a cat back exhaust which is less useful than this LOL
Edit to pozzi:
Edit to pozzi:
Edit to pozzi:
the track cars i've worked on, even for club stuff, we'd strip everything but the essentials. I've ripped the fan and venting system out of Miatas and S2000s just for weight savings. plastic venting tubes weigh nothing, but they're 86'd for pure simplification and weight savings. i've stripped factory harnesses so the unused wires are removed. removed window regulators and pinned glass in place. we'd weigh the sum total of everything removed in the end on most, and although things seem miniscule, the overall total is what ppl are after on a track car.
if you have time to look at another display while at full tilt, you're probably not at full tilt.
there's a reason too that there is normally a minimal amount of gauges in a track car; Tach, fuel, oil pressure, water temp and the latter two normally have a warning light wired in, so there is a visual indicator while on the track. no speedo, no MPG, no trip meter. it all becomes a distraction to the driver. the other gauges, (or a dash/wheel mounted display is normally only used in the pits to view/recall essential and additional info while safely off the track).
my point is, this Mugen TPMS is just a blingy gadget that would not, or should not, ever end up on a serious track car. it's purely a streetcar/showy thing.
That is a good point.
So why buy a STACK then right?
Just install a tach, oil pressure, water temp. That's what, $300 at the most? Good enough for NASCAR good enough for you.
There's all kinds of extraneous BS out there. Shit just put a oil pressure light, a high temp light, and a shift light in the car and call it a day.
I would find that thing useful for setup, idk, you're right not needed on race day, but just an easier way to take data.
