Old 06-11-2014, 11:21 AM
jdmjunkie561's Avatar
Haven't been able to do much more but to enjoy the new suspension till I see what wheels I get one day
  #11322
Old 06-11-2014, 12:06 PM
luismycorreo's Avatar
Originally Posted by Slowira
image by heardthat66, on Flickr
Got some chrome/amber turn signal bulbs to clean up the headlight housing.
Both work and can be seen very well. Just hope they last
Springs and more are on their way, just sharing as the parts come in.
I have a Blue Fit but love your Red one too
I notice that using a LED or Chrome-Amber bulbs for the front turn signals improve the look of the headlights.
Luis
more pictures... click on the link below...
https://www.fitfreak.net/forums/fit-...tit-bijou.html
  #11323
Old 06-11-2014, 03:56 PM
Slowira's Avatar
Jdmjunkie,
Your ride is so sick.
Luismycorreo,
Thank you. Yes, a few light changes and is so clean. Cheap to do and looks good when it's done.
  #11324
Old 06-12-2014, 08:49 AM
Jdmjunkie,
Luismycorreo,
thanks man ...
  #11325
Old 06-12-2014, 09:03 AM
Nice machine man.
Did you publish a list of MODs you applied to you car?
Luis
  #11326
Old 06-12-2014, 09:24 AM
Originally Posted by luismycorreo
Nice machine man.
Luis
Actually no, never did lol don't want to remeber how much money I have dumped into this car lol and thanks
  #11327
Old 06-12-2014, 09:28 AM
Hehehe, forget about money ... just think about the happy moment when the pieces arrives to your door....
Luis
  #11328
Old 06-12-2014, 06:27 PM
MrKeishii's Avatar
Nice looking setup. Idle sounds calm and the revs dont sound ricey. Do you have another vid directly behind the car, from engine startup, idle and rev? I'm also looking for a mild exhaust just for a deep sporty sound that doesn't sound like a weedeater going down the road. I know it's only there for sound and appearance but I still want one. Nice work, Mrkeishii.
Another Sound Test for you
http://youtu.be/7Rv9O8YPTzw
  #11329
Old 06-12-2014, 06:49 PM
Goobers's Avatar
So i installed the accessory leather shift knob.. That thing is small!!!
I had decided to order a bunch of push pin clips to replace the missing bits and threw the knob in the order just for the heck of it (the rubber knob started feeling like it was peeling loose). Looks a little strange to me.
Did the install after pulling the DW65c pump to inspect and subsequently add an o-ring to ease my worries.
  #11330
Old 06-14-2014, 08:45 AM
555sexydrive's Avatar
Picked it up from Seeker after having the transmission and differential completely overhauled. I'm quite happy to have great feeling shifts again. Ryo said my mission was on the cusp of blowing. That would have sucked if I was out on circuit. I knew it was getting worse and worse and after 19.5 months from when it first developed its problem at Central Circuit and several circuit days after, I think I really lucked out.
  #11331
Old 06-15-2014, 08:20 PM
Goobers's Avatar
Finally!!!
While I haven't actually done anything to the Fit, I've been waiting for the readiness code to set... Took a WEEK after replacing the fuel pump and doing some other rewiring for it to finally set.
I was just about to make a new thread about it too.
I was wondering if, during boost (Sprintex supercharger installed), I was somehow getting knock and if that was preventing the code from setting. This thought came about for a combination of two reasons, folks online say 14.7 AFR is too lean for boost (i have the factory ECU handling fuel trim and ignition timing). The other reason, when looking at the scan gauge, my timing reading drops to upper teens, low twenties during moderate to hard acceleration, which is where boost seems to come on. During cruise and very light acceleration, it goes up to 55 (which seems to be the max). Of course that goes hand in hand with the information that the Fit ECU pulls timing if it senses knock.
Of course, now that the code finally set... I'm not worried, but still a little curious.
  #11332
Old 06-15-2014, 08:24 PM
xxryu139xx's Avatar
Originally Posted by Goobers
Finally!!!
u still having SC problems? or u trouble free now?
  #11333
Old 06-15-2014, 08:32 PM
Goobers's Avatar
Trouble free.
Now, to learn about tuning...
  #11334
Old 06-15-2014, 09:43 PM
At the upper rpms, definitely don't be running 14.7:1, even NA doesn't like running that lean when pressing the go pedal. If I were you, I would look to be running at the minimum about 12.5:1 under boost. Some will say that is too lean even. I've never had a boosted car and probably never will unless that new CTR does come to Japan and I allow my wallet to spit out $45k. Anyways, hope you get your tune all sorted out.
  #11335
Old 06-15-2014, 10:14 PM
13fit's Avatar
factory setup wont run at 14.7 AFR, Honda has it running richer than that.
I think someone on this forum stated it shoots closer to 11:1 under anything other then a steady cruise. Cruising steady speed, it probably will be leaner then 14.7 AFR
  #11336
Old 06-16-2014, 12:01 AM
Goobers's Avatar
For the last few days, I've been trying to figure out how to get an AFR reading out of either the AEM f/ic 6 or the Ultragauge... but no dice.
The AEM unit only gives voltage readings, which isn't useful since the primary O2 is a current based wide band O2 sensor.
And until just now, I thought the UG gave O2 sensor 1 readings, but finally understood, it's sensor 2. What threw me off for the longest time was the fact that it's a narrowband sensor, but gauge goes beyond 0-1v range, tops out at 1.250v on the UG. I started thinking it might be lambda... but that got dashed when I realized the gauge name "O2 2" and reading the repair manual, telling me that secondary O2, when operating normally, has a voltage range of 0.05-1.27v (which matches the gauge).
The odd thing is... it doesn't mesh up with the AEM unit's O2 secondary reading. In pretty much all my logs from the AEM unit, the secondary O2 voltage never varies much more than the 0.4-0.5v range. But then again, the AEM unit says it's Bank 2, as opposed to the UG calling it Bank 1 sensor 2. Hum... strange.
Anyway, I decided to order the new version of the Ultragauge, the "EM Plus" version. I ordered it last night because it has a few new "experimental" features... namely, checking readiness and "additional oxygen sensor readouts." But of course, now my Fit set the readiness code, it isn't immediately necessary. In the UG gauge availability estimator, it says only the EM Plus would have "Bank 1 Wide Oxygen Sensor 1 lambda Current" reading for the 2010 Fit, even though a different page claims the classic UG had "Bank 1 Wide Oxygen Sensor 1 Lambda" (I'll tell you this much, I can't find it).
Hopefully, the new UG will give me something to work with.
  #11337
Old 06-16-2014, 01:00 PM
Takeda CAI
I swapped out the factory air box on my 2011 Fit Sport M/T with a Takeda TA-1003P cold air intake. I couldn't say whether it helps performance, but it's way more fun to drive.
Last edited by JonStewartMill; 06-17-2014 at 11:14 AM. Reason: obsolete slang removed
  #11338
Old 06-16-2014, 08:22 PM
Goobers's Avatar
My A/C button broke on me...
Moved my vent controls so air would come out the dash vents... pressed the A/C button.
Decided it wasn't strong enough and I would flip it back to the way it was before... vents to windshield and button OFF (even though A/C would still be ON).
As soon as I pressed it to toggle the A/C OFF, I felt something snap... and now the button is stuck pushed in.
Onto related "issues." I'm not sure if they're actual issues or just my impatience at the time. Fan speeds 1-3, while still working enough that you can feel each is different, they seem kinda weak. Back in 2011, I had that resistor blow out and lost speeds 1-3 altogether.
And the other is, the "cold air" from the A/C isn't particularly cold... might need a recharge or something (I've never done it before on any car, at least not personally).
  #11339
Old 06-17-2014, 10:26 AM
Acri2903's Avatar
Washed it on Sunday and cleaned the dash. Also added a BLOX neo finish shift knob yesterday
  #11340
Old 06-18-2014, 02:47 PM
Slowira's Avatar
Installed some rain visors and a short antenna.
[IMG] image by heardthat66, on Flickr[/IMG]
Quick Reply: What did you do to your GE fit today?
