Just had my first oil change and....
im not saying its not better, but 8 times better than the oil that is used by professional race teams in almost every motorsport?
of course.... 93 octane is for cars that have a higher compression such as the rsx-s. the higher the octane the lower (cooler) the temperature of the gas burns... you can actually cause knocking in the motor if you use 93 when your car is supposed to run on 87 or whatever the number is....
You guys are also missing 1 important reason why it might feel faster... Its a mental thing.... if you get something done to your car you expect it to be better... ex: changing an air filter.... save an old one then after a little while driving on the new one clean the old one and put it in your car with expectations that it will give you more power... you will probably think that it got faster....
I could pick the difference between dirty and clean on my old mini, but then it only had 50hp to begin with, so the restriction caused by a dirty filter was really noticeable.
idk how i could trust that... i mean what doesn't stick to the oil sticks to the inside of the motor
I'm more curious as to why there's a noticable difference. While I can assure you it's no placebo, since I was expecting nothing different, it just felt different from the moment I let go of the clutch pedal...The only possible "crack" thing about this whole situation might have been because it was the first time it was substantially "warm" (around 0°C) around here for a while.
GeneralLee86
08-14-2015 09:28 AM
