OEM replacement garnish in CF!
Old 03-10-2009 | 10:07 PM
speedoholic's Avatar
Where do you buy your carbon fiber? Some place local or online somewhere?
Old 03-10-2009 | 10:43 PM
iKONA636's Avatar
I purchase most of the CF from a local dealer since I would rather help the little guys out even if its a few pennies more.
Old 03-11-2009 | 04:03 AM
iKONA636's Avatar
Bumpety bump bump!
Old 03-11-2009 | 08:14 PM
iKONA636's Avatar
Here you go! The black CF one is finished, It just needs to be wetsanded, buffed and polished ( Thatl be done tomorrow) The red one for Bitoy will also be finished tomorrow, I just have to wet sand that, give it the black boarders, and then clear coat that one.
Tomorrow lll be starting 2 more garnishes in CF, then 2 more the following day. So everybody start placing your orders! I have a few already from a week or 2 ago so I have to take care of those first but get in line while you can. The price will be going up soon since other companeis charge near 50% more then I do. And the companies that chare my price or less dont put half as much work into these. Like I said Id never send something out that I wouldnt accept myself. Enough chat and here are the pics!
Keep in mind! The red one looks bubbly and curvy because I slapped on a thick coat of the resin. The resin I usually sand it with 180 grit paper, then 220, 320, 400, then put on another coat but the red one is on its last coat. So all that sanding gets it as smooth as ice. Then the clear coat will make it look as good as the black one.
Old 03-11-2009 | 08:19 PM
JDM_DOHC_SiR's Avatar
Nice... just make the GE ones as soon as you get the template
Old 03-11-2009 | 09:01 PM
1FiTpINOY's Avatar
Li li li li lick it like a lollipop :P
.......no homo
Old 03-11-2009 | 09:56 PM
iKONA636's Avatar
You lick it like a lollipop!
And the GE ones will be good to go a few days after I get my GE garnish in the mail Like I said its on its way
Old 03-12-2009 | 12:55 AM
iKONA636's Avatar
hmmm... BUMP
Old 03-12-2009 | 12:58 AM
Kittengolf's Avatar
I am waiting to see the GE garnish too. Just to clarify, can these be made without rear wiper delete?
Old 03-12-2009 | 01:02 AM
Fitcapo's Avatar
Yup the I have still has the rear wiper while vtecfit1s doesn't have a wiper
Old 03-12-2009 | 01:14 AM
iKONA636's Avatar
Yes they can be made w out the rear wiper And they will be out soon for the GE
  #32
Old 03-12-2009 | 02:06 AM
vtecfit1's Avatar
i think you might be thinking that because the raised up wiper spot doesn't have a hole in it you think it's the delete panel, but you'd be wrong - one must drill the hole for the wiper to be installed ! the garnish WITH THE WIPER DELETED HAS NO MORE "wiper" HUMP so the ones above are for keeping the wiper it just needs to be drilled out
i recieved two panels for my GD one that was completely smooth = no wiper hump and no emblem hump / and one with a wiper hump (not drilled) and no emblem hump
  #33
Old 03-12-2009 | 03:21 AM
mole177's Avatar
you have enough to do a whole hood ??????
  #34
Old 03-12-2009 | 05:44 AM
Interstate526's Avatar
do you pre drill the wiper hole, or do we have to do that?
  #35
Old 03-12-2009 | 11:38 AM
iKONA636's Avatar
I can drill the wiper hole upon request. And I can do an entire hood but that would cost about 500 dollars. It would be better to purchasee an aftermarket carbon fiber hood.
  #36
Old 03-12-2009 | 11:45 AM
iKONA636's Avatar
And heres an installed pic like you guys wanted!
  #37
Old 03-13-2009 | 02:02 PM
iKONA636's Avatar
Buuuuuuump
  #38
Old 03-15-2009 | 07:19 PM
iKONA636's Avatar
Bumparoo as well!
  #39
Old 03-16-2009 | 08:10 PM
iKONA636's Avatar
  #40
Old 03-17-2009 | 08:33 PM
iKONA636's Avatar
Bummmmmp!!!
