09 Fit all wheels stolen - ADVICE: get wheel locks
#63
The Honda OEM locks are made by McGuard. Shop around on the web and you should able to get them for about $31 plus shipping. The part number is #08W42-SCV-101 (or the last three digits might be '100'; McGuard has assured me that it's the exact same part). I've already got these on my wheels and would like to add a second lock by a differnt company on the chance that whoever is thinking of taking my wheels might know how to work with one type but not the other. Does anyone have a part number for locks from a non-McGuard company that fit and look good on an '09 Sport?
#69
No not really.
It's not like a master key or something like that.
The wheel lock remover needs to be hammered onto the lock. It basically fits over the outside rim of the lock. Once hammered onto the lock, when you turn, it basically is frozen onto the lock. With that, you can remove the lock. Then you need to get the lock off the tool. Generally, you would use a table vice or something similar to then hammer the lock out of the tool. Not something you can do out on the streets really fast. Unless someone bought 4 kits and did this, it wouldn't really be fast.
#70
No not really.
#71
My wheels were stolen on Wednesday morning. I'm pretty ticked and feel pretty violated! Will a tilt alarm really work? I have set up security cameras in case they come back. Do you think they will come back for the el cheapo wheels I put on instead of the OEM's?
Thanks,
jazzman
Thanks,
jazzman
#73
I ordered the GORILLA 38431N wheel locks from Summit racing, about $25 with shipping. They installed in seconds on my '09 Fit Sport and look quite good, even better imo than the Honda OEMs (which are made by McGuard). I've driven about 70 miles on them and there's no sign of them loosening up, as someone in another thread said they might. I'll certainly post again if they do. Also, they use a very different type of key than the OEMs and, as I now have both types on my wheels, I think there's a fair chance that someone thinking of taking my wheels might know how to remove one type but not the other. If it works I suppose I'll never know; if it doesn't I'll post again.
#75
yeah, but with an alarm with shock sensor, using this tool, banging it onto the lock, should set off the alarm. they tried to steal my aftermarket wheels when I had my 07 Fit, but the alarm, which is attached to an air horn, went off and gave such a ruckus, it must've scared them off. do yourselves a favor and get an alarm with a pager, and DO NOT buy cheap wheel locks such as the ones found in AutoZone or similar. it turns out, the keys are all the same for all their locks. I use McGard and Gorilla Guard, plus a pager alarm with glass sensor, and probably will be placing a motion sensor, for my new ride. like everyone says, it not 100%, but it should deter thieves.
#76
Say, do you have some kind of trim all the way around the wheel well? Is it a protective thing? I have a base too.
#78
So, last Wednesday, I woke up at 5 am to walk my dogs and realized that all my tires had been stolen off of my 2009 Honda Fit Sport. I was so heartbroken. The idiots sat my car on some milk crates, which ended up breaking under the weight of the car (duh!), which caused my car to fall and damage the underbody kit. With no tires, they had to drag my car up the tow truck, damaging the rotors and God knows what else. Got the call yesterday from the claim adjuster and, thus far, the damage exceeds $3000. They will further determine what other damage is done once the car is able to be put in the air and examined underneath. Kinda sucks! I've only had my Fit since January. Any suggestions other than wheel locks? Any alarm systems sensitive enough to go off when my car is lifted, if it's lifted up again?
