Hard-Wired Radar Detector
Old 08-30-2010, 09:52 PM
TWFM070810's Avatar
Originally Posted by Committobefit08
Thanks...I would like to have it turn off with the car. I'll have to figure out a way.
all you need to do is tap one wire at the cigarette lighter power, run it behind the glove box, then behind the A pillar panel then roof liner. I use the the dome for the ground. no switch needed it will turn off with the car. thats what i did to hard wire my gps.
Old 08-31-2010, 09:48 PM
specboy's Avatar
Originally Posted by bkrell
You won't hurt it by leaving it plugged in and cutting the power. To the OP, nice setup. Is that an XTR-695?
Correct, My V1 came with a hardwire Kit when I got it (10 yrs ago) and all it does is cut power. I have it tapped into the Fuse box using an add-a-fuse and at the 12v Accessory (Cig lighter) fuse location. No cutting, splicing, etc... and it does everything I need.
Correct, that's exactly what I did but instead of going to the back of the Cig lighter socket or finding the wire, I tapped into the fusebox using an add-a-fuse. If I ever get a dedicated GPS, I'll hardwire it this way too. For now, I just use my Omnia WinMo 6.5 Phone with Garmin for GPS.
Click the link in my sig for a DIY on my V1 hardwire.
~SB
STTICH
11-01-2014 03:51 AM
xknowonex
07-16-2009 10:50 PM
xknowonex
07-16-2009 12:14 PM
gawa
01-16-2009 02:59 PM
Darkstars
07-07-2008 12:09 PM
Quick Reply: Hard-Wired Radar Detector
