Alternatives to replacing cracked fog light lens
So as predicted by that little pr!@k Murphy, a rock takes aim like it had eyes and breaks my left-hand fog light lens. It's now cracked, with a 3/4-inch triangle missing from its geographical center. I've temporarily taped it up with clear tape to keep water and debris out.
"Oh good, it's only the lens. I'll just pick up a new one at the dealer."
"Oh no, sir" replies the grinning parts manager. "You have to replace the entire unit. It's only $325."
"You're joking, right?"
"Plus installation. Plus tax. Should still come in under $450 installed."
NO.......... F&%@ING...... WAY...... that's ever gonna happen!
I *could* custom make some new 1/4-inch thick ones out of plexiglass. These could then be sealed over both lights to protect them from further rape and pillage.
But I'm wondering if there's an easier method, specifically a clear spray-on synthetic rubber compound that could purchased locally. I've already tried many of the auto supply stores (Napa, Canadian Tire, Auto Value, etc.) to no avail. Does anyone know if such a product is readily available, what its brand name is and where available? I'm in the Calgary Alberta area.
I may go this route, but that still doesn't address the entire issue, ie: the vulnerability of these lights to death by stoning. The multiple layers of 3M would also work and what's even better, I wouldn't even have to replace the existing damaged lens. I'd do both lights of course to protect the RH light as well as the already cracked left side.
I'll probably trade this car in after 5 to 7 years for a new one and by that time these assemblies should be available at aftermarket places and wrecking yards on the cheap. Thanks again.
How come u didn't cover the area with lamin-x or xpel? It could have avoided the problem. I even have a writeup. U could just try putting it over the existing glass. It will hold up and protect the rest of it and it'll b cheaper then replacing the whole unit. If it didn't work, ur only out $5 then u can buy the replacement.
I've just called Napa. they have a 3M equivalent. I'll just pick that up along with some modeling clay to make a mold of the lens from. I'll use this to cut out one layer, check the fit and then use that one as a template for all the other layers. I'll report back with the results.
We've had several Hondas, all had foglights, and when we traded them, they all had at least one broken foglight lense... and we're really careful with following distance. For this one I bought the bulk film from XPEL, it's meant for fogs and it is THICK. Cost about $15 to do both fogs, which included shipping. I bought a little extra film for misc other projects. Well worth it.
You can change the light yourself, it should take no more than 10 minutes.
Fog light cracked on me too. I went to my local honda and asked for the replacement lense and got the bad news about having to buy the entire housing. I ended up paying $280 if I remember correctly. Sucks but I didnt think I had another alternative. I will definitely use the link in this thread if I have to buy another.
Headlight Protection
I bought the bulk sheet, you'll just have to mark it out... and you can cut the film with a pair of scissors.
Ok, here's the promised update: I went to Napa and bought a pair of 12" x 17" sheets of very similar stuff to your example. Napa calls it "Ricochet" film, and it's a clear film about half a millimeter thick. Cost was $32 (+ tax) here in Canada.
Turns out I only needed one of these sheets so I gave the other one away to a co-worker. I picked up some Play Doh and used the plastic bag it came in as a release agent. I then squished it into the recess of the fog light, making a mold from which I could cut the first layer using an Exacto knife.
It took a bit of final tailoring but I finally had a decent template from which I could slice out the remaining required layers. Leaving the backing paper on the template I simply pulled the paper off the subsequent layers and placed them over the original template.
With a total of five layers now pressed together (I required the extra rigidity due to the hole in the lens) I was able to remove the paper from the original (first) layer and then simply stick it to the outside of the broken lens. The unbroken right-hand lens got three layers. Problem solved.
The un-cracked one could have gotten away with one layer, but I'd already cut out the extra two, so...
was just browsing the website of the company that bought my old WRX from me and came across this interesting solution...
IAG Performance: RockBlocker Yellow Fog Light Kit for Subaru WRX 2002-03, RS 1999-03, Lighting, S101YELLOW
I posted this a while back. I'll re-post it:
I just applied Lamin-x today. Bought a 8" x 16" bulk film sheet. 40 mil thick for fog lights.(clear) $19.95 plus $9.14 shipping. Came with a small spritz bottle, squeegee and easy instructions. They also have smaller sizes if you don't want that much. ( I see it's on sale now for $17.96!)
That size sheet will make 8 lens covers. 5 down the left side and 3 on the right. So I have extras if or when needed. Instructions said to re squeegee edges in 24 hours, so I'm keeping the lights in my house overnight and will re squeegee and install in the morning. Also getting into the 20's tonight so adhesive will probably set up better inside. Once on, the lens is easy to trim with a blade.
Lamin-x Protective Films - Protect with Style
Sooozun
01-31-2013 10:36 PM
