Non stop horn
Old 10-30-2008 | 02:59 PM
CrystalFiveMT's Avatar
Non stop horn
I'm in the midst of finishing installing my Fiamm El Grande horn, but when I put the fuse in the horn wouldn't stop.
Any electrically-savvy people know what's going on?
Thanks.
Old 10-30-2008 | 03:08 PM
CBX's Avatar
CBX
Mine just shipped yesterday, so I'll have them soon.
It sounds like a couple of the wires are switched. Does the relay have three terminals, or four?
Old 10-30-2008 | 03:13 PM
Fit_to_be_tied's Avatar
it sounds like its wired wrong, you know that hondas control the ground side not the power side right?
Old 10-30-2008 | 03:18 PM
You see! I have no idea what your lingo is. Relay? What's that? But the terminal has 5 I think, but 1 isn't in use.
Ground side? Power side?
Old 10-30-2008 | 03:21 PM
CBX's Avatar
CBX
If there is only one wire on the stock horn, that wire has to be hot (+12volts).
I copied this link from another post by SOL_GT;
Relay Wiring
How does your wiring diagram compare to this?
Old 10-30-2008 | 03:31 PM
no offence but if you have no idea should you be doing it at all? however the manual only shows one wire then it grounds through the horn so it seems like it would be hard to do wrong. is the new horn grounded well?(mounted to a clean metal surface)
Old 10-30-2008 | 03:56 PM
CBX's Avatar
CBX
C5MT,
Does the diagram look something like this?
http://www.cartestsoftware.com/fz1/d...tallation.html
Scroll down, under "Revision" and click diagram.
The original Fit horn won't have the black wire if there is only one.
Old 10-30-2008 | 04:03 PM
don't know the link doesn't work for me
Old 10-30-2008 | 04:15 PM
Relay Wiring
I'm printing that diagram right now and I'll head out to my car and compare. Stay tuned...
Old 10-30-2008 | 04:16 PM
C5MT,
http://www.cartestsoftware.com/fz1/images/dhwiring.jpg
Sorry that link doesn't work for me either.
Old 10-30-2008 | 04:28 PM
CBX's Avatar
CBX
Old 10-30-2008 | 04:45 PM
i guess the next obvious question would be if you put it back to stock does it work properly? if so something you did was wrong and if not something you did wrecked something.
Old 10-30-2008 | 05:09 PM
Okay, rerouted some wires and PRESTO!!! Big horn!!! EL GRANDE!!!
Thanks CBX for the diagram. It looked a little different than the instructions on the box, so I switched a few wires around and that worked.
I just hope my car isn't going to exploded due to my novice install, hehe.
Thanks again all.
I honked a few times while parked to test and it sounds pretty much identical to my 08 Accord horn. Loud and non-wimpy. Can't wait to honk at everyone on the road.
Old 10-30-2008 | 05:15 PM
My special thanks to TKZ12NO1 for posting his thorough procedure, review and vid on this horn. He was responsible for the successful easy install.
Old 10-30-2008 | 06:01 PM
jdmgpw04's Avatar
yes honda uses the brackets for the negative terminal...... the horn only uses 1 wire for positive...
try wiring the other to the negative (which would be the brackets)
NEVERMIND DIDNT SEE YOU FIXED THE PROBLEM.
Old 10-30-2008 | 08:24 PM
TKZ12NO1's Avatar
Thanks to you, glad it all worked out in the end.
Honk Honk
Old 11-06-2008 | 12:55 AM
CBX's Avatar
CBX
Here is the wiring diagram;
dbcmaster
05-16-2017 07:34 AM
SuperMacGuy
03-27-2013 09:14 PM
hybridctr
09-20-2012 11:01 PM
BenjaminFit
12-07-2010 07:38 PM
duckbill
07-05-2005 07:44 AM
Quick Reply: Non stop horn
