Head light bulbs
For the most part, HB2 = H4, so you can run a halogen H4 bulb regardless of whether you pull fuse 15. Removing fuse 15 will just kill the DRL functionality so your high beams won't be run at partial power during the day. This is also required if you run an bixenon HID kit which replaces the halogen bulbs with H4-fit capsules.
More info on differences between H4 and 9003/HB2 bulb specs...
http://candlepowerinc.com/pdfs/H4_9003.pdf
mxl180
08-03-2010 06:35 PM
YeeFit
03-29-2008 12:28 AM
