Is the Fit electronically limited?
Old 10-20-2008 | 11:43 AM
CTStalker's Avatar
I was driving my '09 Fit Sport MT quite...uh...exuberantly...up in Vermont, and I was on a long straightaway with no other cars and perfect visibility in the middle of nowhere (in other words, don't try this at home) and decided to see how far I could push it. When I hit 105 (), I couldn't get it to go any faster. It felt less like I was hitting the limits of the car and more like I was hitting some kind of soft electronic limit. I tried it again and got the same feeling at 105, and never went a centimeter over. If anyone cares, I was at about 5000/5500 RPM ish at this point. Is the Fit limited? What's the top speed that you have hit (stock)?
Old 10-20-2008 | 11:59 AM
Virtual's Avatar
Try going downhill. If it still blocks at 105 then we'll know.
Old 10-20-2008 | 12:51 PM
CrystalFiveMT's Avatar
The GDs which should be a tad slower, (wider tires, more aero drag, way less top end power) hit 118 for Car and Driver. I would conservatively estimate 120 for the GEs, though none of the mags have done a top speed test on the 09s, so being electronically limited is still in question.
Old 10-20-2008 | 03:56 PM
WiggumS2K's Avatar
I'd do 120 in my S2000, but in the GE, no way sir. Be smart, Drive safe.
Old 10-20-2008 | 04:12 PM
kylerwho's Avatar
spoon fed
the gd is limited at 115mph and the ge is limited at 110. not sure why but thats just how it is. any way to bypass this?
Old 10-21-2008 | 07:15 AM
wpyeo's Avatar
my JDM GE8's speed cut limited @ 170kph, or 105mph..
rev cut @ 6800rpm, neutral gear rev cut @ 4500rpm.
a RSM should be able to overwrite the default settings.
manhattanmike
05-15-2017 08:00 AM
siguy
05-04-2014 09:48 PM
Nawamin
03-19-2012 07:25 PM
colliewagon
05-06-2010 09:11 PM
billmus86
Car Shows, Events, and Racing
59
12-26-2008 09:29 PM
Quick Reply: Is the Fit electronically limited?
