USB Port to Charge cell phone, etc
Has anybody tried connecting their cell phone, palm pilot, bluetooth device, etc to the USB port to see if it charges it? Clearly, there won't be any data/music connection . . . but I have several devices that can be charged when connected to the USB port of a PC.
I've heard that this is a powered port (it charges an iPod), but didn't know if it would charge anything else.
I wonder if you could use a usb hub with this? If so, could it provide enough current to do all kinds of things?
a hub like this:
maybe add a usb notebook light to the glove compartment? like this:
Hong Kong SAR USB LED Light. Manufacturer
nah, you might as well spring for the flexible usb powered "neon" light. like this:
On Sale, buy Magic neon wire - blue Flexible USB Neon Wire - USB or Battery powered
or maybe keep a beverage cold in there? like this:
Google Image Result for http://www.slashgear.com/gallery/data_files/1/4/6/usb_fridge_front.jpg
a hub like this:
...or maybe keep a beverage cold in there? like this:
http://www.honda.co.uk/cars/_assets/.../jazz/Jazz.pdf
pg 35 in the brochure (pg19 of 27 in the pdf file)
I want that!!!!!!
Nah, people have confirmed that the iPhone, 3G or otherwise works fine. The charging issue people though might occur is because Apple stopped allowing charging from the firewire pin on the 3G iPhone. It only charges on the USB pin now, but that's no problem since the Fit uses USB anyway. The reason that the phone will ask you to put it in airplane mode is to cut down on GSM buzz that can sometimes come through unshielded speakers. This only happens if the phone is on the EDGE network, not 3G, and as far as I know, people haven't had any problems with GSM buzz at all. It can vary from car to car. I get no buzz in my wife's Prius, but I get it in my work vehicle (Dodge Caravan) if I don't keep the phone far from the speakers or head unit.
Jawbone 2 USB Charging
I got a reply from Jawbone Corp regarding the Honda's USB connector charging a Jawbone unit:
Dear Tom,
Thank you for your inquiry!
The USB charger cord that is supplied for the Jawbone 2 would work great in your Honda's built in USB port.
As long as you use the actual USB cord that was supplied for you it should work fine!
If you have any future emails don't hesitate to email again!
Sincerely,
Moriah
The Jawbone Support Team
Dear Tom,
Sincerely,
Moriah
Are you referring to the Jawbone manual? I don't have it anymore that's why I wrote to the Jawbone company directly. Is a "hub" different than the USB port in our cars? Your teachers are very wise indeed...if you don't toss out the manual! LOL!! Hopefully the Jawbone company is wise as well and wouldn't give out misleading information.
