I put in a BAD BOY™ AIR HORN
http://www.harborfreight.com/bad-boy...orn-94117.html
This is a major improvement. I did not know it has a separate horn for when you lock the doors. This is very nice it does not sound the air horn when you lock the doors. This horn is loud but that is how a horn should be.
(You need to install a relay with this horn)
It pulls much more power than the stock horn and circuit was designed for.
It has it own sound.
This link will play the sound BE CAREFUL very LOUD!!!
http://www.autobarn.com/images/miva/...ounds/419a.wav
details
small only 2-1/2" W x 4-1/2" L x 4-1/2" H
"2x louder than factory horns
This "bad boy" gets everybody's attention. Dual tone air horn is twice as loud as your factory horn.
- Easy installation, uses existing factory wiring
- All-in-one design, no separate compressor or hoses
- 118 dB, 530/680 Hz
- Compact unit works with any car, truck, motorcycle or boat with a 12V system "
Is it a deep tone?
I really wanna get a loud deep trucker horn on my Fit, but still keep the original for use when needed.
Not sure how the Bad Boy sounds, but the one I pictured is not as deep as a Trucker's horn. You would need a bigger Horn and a larger compressor for those. The smaller one is actually louder because you don't need as much air to power it.
I've used these...
I have used the compact horns from this company, on motorcycles, they worked very well.
http://www.fiammamerica.com/HornsIntro.asp
A Better Link, for a look...
http://www.fiamm.com/product/product.aspx?catid=0.13
_
FitStir
09-03-2012 12:07 AM
