Is the oil drain plug recessed?
Old 11-03-2008, 09:59 PM
TheSaint's Avatar
Originally Posted by FitStir
...So is the 106N the correct size/part for the 09 Fits?
If memory serves me correctly, yes. You can use the F106 or the F106N. The difference being that the F106N has the nipple attached while the F106 does not. But if you want to be sure, you might want to call their toll-free number (1-866-822-5689) and let them tell you which valve is correct. That is what I plan to do.
Old 11-03-2008, 11:20 PM
badself's Avatar
Originally Posted by Blazer Deli
Please post the direct link to the plugs that fit the FIT.
http://www.quickoildrainvalve.com/Se...ts.asp?Cat=152
Old 11-03-2008, 11:40 PM
animes2k's Avatar
Thanks! I've heard about this for a while, but finally ordered one for the Fit!
Old 11-21-2008, 03:37 PM
triton.'s Avatar
So for the above link, do we need to get one with the adapter or not for 09 fits? I'm looking at getting this one without the adapter, is this the correct one?
QuickOilDrainValve.com - the best way to change oil
Also does the oil drain the same speed with the nipple or without? I'll spend the extra $3 for the flexibility and option to use a tube later on.
Old 11-21-2008, 04:13 PM
AZEqualizer's Avatar
Smile
Originally Posted by badself
For anyone interested, coupon code YM4 gets you 10% off the Fumoto valve:
Thanks for the coupon code. I have had the Fram quick drain and the Fumoto. Even though the Fumoto is just slightly more expensive it is much better design in my opinion. And I am not one to turn down a extra savings of $2.60 on something I was going to already buy.
Old 11-21-2008, 10:28 PM
triton.'s Avatar
Did you get the one with or without the adapter piece?
Old 11-22-2008, 02:39 AM
Fitlurker's Avatar
The '09 Fit does not have a recessed drain plug port and therefore the adapter is not required. But you have the option of a nipple.
Old 11-22-2008, 10:16 AM
triton.'s Avatar
Me likes nipples
Old 11-22-2008, 11:23 AM
You don't need the adapter piece.... it just extends it out further which in some vehicles it is necessary to do extend it... but I did get the nipple for a hose.
Old 02-16-2009, 07:16 PM
txmatt's Avatar
Question
Has anyone changed their oil in a GE yet with the Fumoto in place? I did an oil change today and put mine on (I have the no-nipple version). I'm skeptical that it's going to work as expected. As I recall from previous Fumoto's, they spit out a pretty good stream when opened up. There's a plastic shroud under the Fit that has clearance to get to the drain plug, but not a lot of extra clearance. I kinda think that the stream of oil may shoot out far enough that it is going to hit the plastic shroud. That would create an unholy mess worse than just using the drain bolt.
Hopefully someone will chime in before my next oil change so I know for sure. If not, I'll likely go ahead and order another Fumoto (with nipple this time) so I don't have to remove a bolt/plug for a third time to drain.
Old 02-16-2009, 08:24 PM
AWDturbo's Avatar
I've changed my oil twice already, the first time mounting the Fumoto valve upon completion, and the second time actually using the valve. I've always used the versions with the nipple, and it worked fine for me. The oil came out at perfectly manageable pace - no mess.
I've found if you want to slow the oil down to minimize potential messes, don't remove the oil cap or dipstick.
Good luck - hope all goes well.
  #32
Old 02-22-2009, 02:30 PM
TunaDaMan's Avatar
just for curiosity sake, would this valve be useful as a way to make an oil return from a turbo, or would it just be too small...might be less hassle instead of having to drill the pan or whatnot...just a thought i had after it came in the mail
  #33
Old 02-25-2009, 01:47 AM
EUROz*JDMz's Avatar
Thanks I just ordered 2 one for the FIT and R32, the 10% coupon works! Mahalos.
  #34
Old 02-25-2009, 03:44 AM
Fa1's Avatar
Fa1
Fa1 is offline
Get an oil filter sandwhich plate if you don't want to drill. Drilling is the best option though.
  #35
Old 02-25-2009, 07:32 AM
SheepNutz's Avatar
Just make sure that you don't piss off any friends that know you have this installed. They could quickly and easily drain off all of your oil without you knowing.
  #36
Old 02-25-2009, 11:19 AM
Bustov's Avatar
Regarding self oil change. Ho do we reset the Oil Change computer?
  #37
Old 02-25-2009, 11:48 AM
txmatt's Avatar
p248 of the Owner's Manual
Resetting the Engine Oil Life
Display
Your dealer will reset the display
after completing the required
maintenance service. You will see
‘‘ OIL LIFE 100% ’’ on the information
display the next time you turn the
ignition switch to the ON (II)
position.
If maintenance service is done by
someone other than your dealer,
reset the maintenance minder as
follows:
1. Turn the ignition switch to the ON
(II) position.
2. Press the select/reset knob
repeatedly until the engine oil life
is displayed.
3. Press the select/reset knob for
about 10 seconds. The engine oil
life and the maintenance item
code(s) will blink.
4. Press the select/reset knob for
another 5 seconds. The
maintenance item code(s) will
disappear, and the engine oil life
will reset to ‘‘ 100. ’’
Henus
12-20-2018 02:17 PM
lmgpr7
07-24-2018 09:29 PM
Hadrian
05-30-2018 02:10 PM
SlavetotheHonda
09-27-2015 09:28 PM
Quick Reply: Is the oil drain plug recessed?
