Synthetic vs Conventional Oil - Any comments?
#164
I spoke with the head honda tech which is one of my good friends. He said that there is no reason or no need to use synthetic in th Fit. The engine is not made for synthetic nor will it help it in any degree. I trust this man with my car's life 25+ years at the same honda dealership. He said its not the money factor, its just Honda designs these Fit engines around conventional oil.
#165
If anybody tells you a particular car or truck is not designed for synthetic oil they are speaking from pure ignorance. Synthetic oil is just far superior to dino oil period. Anybody who tries to tell you different is speaking from pure ignorance ( not stupidity, just ignorance).
I, both tech and engineer, and Honda engineers all state that synthetic oils are the lube of choice because they can design the engine for lower friction losses as a result oif requirementsfor higher mpg. Its not that conventional oils won't lube but that they just don't do it nearly as well. Thats especially true if you use 10W-30 dyno oil. Besides, dozens of dyno runs here prove the point both in power and mpg as well as wear on internals.
Eugene.Atget
12-11-2010 07:21 PM
mav238
09-18-2010 07:29 PM
