Is the spoiler removable? (without body damage)
I'll be honest, I'm not crazy about the spoiler. The rest of the body kit looks great though.
Can the spoiler be removed without exposing screw holes or other body damage? I'm not sure how the spoiler is attached.
Unfortunately I didn't take any pictures of what it looks like, but there are 5 holes. The 3 holes in the middle are larger, unthreaded holes with white nylon female clips stuck in them and the 2 on the outside are smaller, threaded holes. The area of the body around the 2 outside holes is recessed in a bit and the actual threaded hole is raised a bit. Look to spend a decent amount at a body shop to get these covered up, at least a few hundred.
I was able to swap hatch doors with a Base Fit owner of the same color who was local. Once you know how, swapping doors is really easy. If you can find someone to swap with I can tell you how to do it.
I agree 100%. The '09 Sport will look super clean without the window awning tacked on the back.
I was planning on pulling the rear spoiler off mine (new '09) to see what was underneath. I expect there to be 2 holes that are threaded inside. Hoping there are not more holes. I'm pretty sure I can find plastic or metal plugs that I can prime, paint, and use sealant to ensure they don't leak. Swapping with a base owner might be an option as long as the base hatch had the rear wiper.
Dr. Unsped
02-19-2011 09:00 PM
TeamStaNceFIT07
02-29-2008 10:05 PM
07fitsport
16
10-04-2007 10:41 AM
