Unlock my doors, please!
#201
For some reason the methods above didn't work for my car to have doors unlock when I turn my key out of the ON position.
I have an AT Sport.
I did the following for my doors to unlock when I switch to off (this is in the manual) but the following is from my memory:
1) Pull up E-brake, Insert Key, Switch to the ON position (don't start the engine, make sure doors are closed
2) Press Brakes, Twist Key and start engine, switch from (P) to (N) Neutral.
3) Hold Unlock button for 5 seconds, hear a click (don't let go yet), wait another 5 seconds and hear a 2nd click, then let go of unlock button.
4) switch from (N) to (P) Park, let go of Brake, Twist key from On to Off and remove.
I have an AT Sport.
#202
About post #185 on page ten of this thread-
You must take your key out at the end- not just turn it to the off position leaving the key in. Also, pushing and holding the door lock refers to the door lock button on the drivers door, not the keyfob. I know that seems obvious, but the first time I read through all this I assumed it was the keyfob.
I noticed something just last week and I don't know if this has always been so, or the reprogram causes it. If you push unlock on the keyfob and don't enter the car before the interior lights dim to black, the car locks itself again. Is this a normal, default setting? It seems reasonable even if it is, but I'm just wondering.
Dan
Dan
#203
Hmm...you have a point. Unlocking the doors when switching to P is more logical instead of having to switch it off.
#204
Dan
#206
Works great! as one posted before, you have to take the key out as soon as the second click happens. theres one click immediately then 2 at 5 sec intervals. after that take the key out wait a sec. to test it: turn your car on put it in neutral then throw it in park and it worked! THANKS GUYS!
#208
This is from memory, so forgive me if this doesn't work:
- Insert key and turn forward 2 clicks (don't turn engine on).
- Press and hold the door lock button to its "unlock" position.
- After 5 seconds you'll hear a click. DON'T LET GO YET! Wait another 5 seconds until you hear another click.
You're done.
Hope that works.
You're done.
Hope that works.
Just turn key to off after you hear the 2nd click..
Thank You
#209
"P's" a better deal IMO...
I've found this auto unlock when in P (on my AT) a better deal... Previous to this setting change my 'ol lady (and other passengers) would fume about being held captive whenever I forget to hit the master unlock door button right away!
Now when in P all the doors unlock for everyone right away, and it's a real simple thing for me to just hit that master door button to lock all the doors again as I exit the car. -And of course the keyless fob's remote unlock makes it easy for me to get allus back in again...
#211
Same deal here on our new 2010 Blackberry Pearl Sport A/T...thanks! Doors lock automatically when putting in reverse rather than 9 mph but that's ok. The main thing was the unlock all when putting in park
BG
#215
I'm from USA and if i'm not mistaken it can only be
done to our cars. Meaning the usdm body type which
is in serval other contries.
#216
Thanks for the 411 CrystalFiveMT!!
#217
I have a stupid question about the back door locks. Can't find my manual. I think we have it in the childproof mode for the back door which won't open from inside. Help. Thanks. This is a 2008 Fit Sport automatic.
#219
this is for GE8 Fit's
you have a GD3
you might have to go to the GD section
to find what you need.
