iPhone 3G and '09 Fit
My 3G worked fine as far as playing music went. I didn't bother to leave it long enough - primarily because I use a separate iPod.
When you plug in your iphone, a popup appears on your screen asking if your like to switch to airplane so theres no distortion in the audio. You select no to stay in the standard mode so you still can receive calls. And if you get a text message or get a phone call during the middle of a song, the music volume turns down and your ringer goes off over the radio. Good luck talking on your phone while its plugged in (the standard usb-to-30 pin Ipod plug doesnt reach far)
I bought a car charger for my iPhone from XTreme Mac...it's black and came with a black iPod USB cable that's plenty long enough to talk with while it's plugged in.
http://www.xtrememac.com/chargers/in...auto/index.php
I use an iPhone 3G plugged into the USB port and use a Bluetooth headset. The only are of the iPhone that is"locked" while plugged into the USB oprt on the Fit is the iPod controls; You can look at all you other apps, make phone calls, etc, all without unplugging you 3G.
I also have a 120gig iPod with 18,000 songs on it. The Fit controls on the head unit are not very convienient for browsing when you have alot of content. Is there a faster way to get from "A to Z"??
Okay, this may be a stupid question, but my excuse is that I don't own an iPhone yet. Just thinking about it right now. Anyway, my question:
Can you get turn-by-turn directions on your iphone, and then through the stereo? If so, this would make the extra $1,800 for the Navi fairly irrelevant! If so, how does it work with playing music at the same time?
You just leave the cable in the glove box plugged into the USB port, and when you connect your phone to it, you can then control the iPod function of the phone on Fit's radio.
One of these cables comes with the iPhone, but I have 4; one at my nightstand (with wall outlet adapter), one at my computer, one at my work, and one in the Fit.
If you have an 09 Fit sport, you just need to get an apple iPod USB cable, like this: Apple Dock Connector to USB Cable - Apple Store (U.S.)
Well, no. You can't get calls through the nav system like you would through a bluetooth setup, but if the phone is plugged into the USB port and playing music, and you get an incoming call, the music mutes and your phone will start ringing. You can then answer the phone (and leave the cord connected, although it barely reaches to the driver's side ear), and when you hang up your call, the music will kick back in. If you have a bluetooth headset, you can do all of this handsfree by using the headset to answer the call.
I just got my Fit Sport tonight. First thing I tried to do was plug my iPhone in and I get the unsupported error on the radio. No navi, just what comes with the sport.
So I was kind of disappointed, but it seems some people have got it to work. I wonder if this is an Iphone or Honda issue with compatibility? I have the latest iPhone software.
#32
Are you sure that the last thing you played on your iphone wasn't a video or video podcast? Whenever I just got done watching a movie in the ipod app and plug it in to the Fit, I would get unsupported. Start playing the music on the phone, then plug it in and see what happens.
#34
When a call comes through, the music stops playing in the Fit, but plays through the headset instead. I can't hardly even hear the person on the other line because of the music.
#35
How are people getting past the issue of the music continuing to play through the bluetooth headset?
#36
i'm using the usb. i don't usually start a song before i plug it in though. i let it start automatically when i select usb.
i'll have to try it again, but so far i have no had success. the music always plays through the headset for the duration of the call. once the call ends, it will start play in the fit again.
i don't have this problem in my c350 though. music plays through the car and when a call comes in, i can pick up the phone call with the built in bluetooth on the car. the music always stops. wierd...
Firephoenix1980
05-17-2012 10:44 PM
