Hid's And The 2009 Fit
JUST WONDERING , I HAVE LOOKED AT A NEW 2009 FIT IN PERSON AND IT HAS DAYTIME RUNNING LIGHTS(I HATE THEM ON ANY CAR) BUT DOES ANYONE KNOW, IF IT'S POSSIBLE TO INSTALL A HI/LO HID SET UP LIKE ON MY 2007 SPORT, WITHOUT THROWING ANY CODES ?
Hid's Part 2
I Have Pulled Out The Bulb For The Fit 09 And Here Is What I've Found
Uses A Hb2 Bulb (two Filiment Bulb) Drl Is Hi-beam (rear Filiment) With Low Voltage
Lo-beam Is Front Filiment With Regular Voltage
Hi-beam Is Rear Filiment With High Voltage
On Some Honda's The Drl Has A Designated Bulb But The 09 Fit Just Uses The Regular Headlight Bulb And Just Limits The Voltage Going To It (lame)
Does the 09's have flash-to-pass lights, where you pull the stalk a bit to flash the brights?
If so, will folks be disabling that for bixenon HID kit installs? Many factory HID vehicles either retain halogen bulbs for the brights or don't offer flash-to-pass because those short strikes are really hard on the capsules.
If anything, normal low beam headlights will produce more glare at night.
