Cooling Issues Catalytic Converter delete + cold air intake
Old Today | 08:05 AM
Eras's Avatar
Hello Family,
I drive a 2nd Gen, 2011 GE8 RS 6-Speed manual with an L15A engine.
I recently deleted the two mufflers and did a straight pipe exhaust and everything was okay up until I installed a cold air intake.
Now my car is ever showing sign of overheating.
So the story is this, after the muffler delete all was good then one day my OEM radiator gave in and replaced with a new one OEM and radiator cap changed as well.
After this I bought and installed the cold air intake, again all was good until it wasn't. Now I keep suffering from overheating and my mech tells me it could be due to the cold air intake hence the engine is struggling.
I wonder whether to go in for a tune, or just get a perfomance 3-row radiator to sort out the cooling issues.
I really need advice on this as my once lion-like car is now being reduced to a mere cat on the roads.
Regards
Erastus
Old Today | 10:12 AM
Drew21's Avatar
Did you try removing the Cold Air Intake to see if your issue went away?
Many folks have posted here about issues with Cold Air Intakes. It seems like the main problem is when the intake tube diameter is different (=larger) than stock, which causes improper readings from the MAF sensor. I'm not sure if odd MAF sensor readings could affect the cooling system, but maybe.
I would: 1) determine if the Cold Air Intake has the same diameter as stock leading to the MAF sensor and 2) remove the Cold Air Intake (for a while) to see if the cooling issue persists.
Old Today | 11:37 AM
Eras's Avatar
Thanks @Drew21 I'm actually getting rid of the cold air intake for now.
I have seen the diameters are similar. But let me revert to factory settings first and see if the cooling issue will persist.
Thank you so much
Old Today | 12:35 PM
Frenzal's Avatar
Was the coolant properly bled when replacing the radiator?
Old Today | 01:33 PM
56chevydan's Avatar
Two issues come to mind. Are your engine cooling fans working? One is thermally controlled and the other one comes on when you turn the a/c on.
The second issue is your catalytic converter delete. Did you delete the catalytic converter and the muffler or the muffler and resonator? If you deleted the catalytic converter, did you also remove the primary and secondary oxygen sensors? If so, why?
Lastly, do you have a check engine light on? If so, what codes are showing?
Old Today | 03:08 PM
Eras's Avatar
@Frenzal this was properly done I believe. But I may just have to try it out again tomorrow.
Old Today | 03:12 PM
Eras's Avatar
@56chevydan about the engine fans, we've checked and they are working. After the engine runs for a while they run and shut as they should.
Yes I deleted catalytic converter and muffler.. resonator was retained and the two oxygen sensors as well. We did use some junction to 'cheat' the oxygen sensor at the bottom so with this check engine light was successfully evaded.
Old Today | 07:09 PM
56chevydan's Avatar
I'm sure you have a legitimate reason for deleting your catalytic converter, but I can't think of one. You drive a computer controlled car with smog controls and signals that adjust the air fuel ratio based on the signals to the computer by the oxygen sensor.
The closest oxygen sensor to the engine is considered the air/fuel sensor and the downstream sensor senses the condition of the catalytic converter. Without the oxygen sensors reading correctly, and with no catalytic converter, are you sure info isn't being sent to your computer causing the air fuel ratio to completely go lean, thus causing the overheating?
As far as your fans go, the fan that goes on with the a/c being turned on, should not go off until the a/c is turned off. It should not cycle on and off.
TheTexan
03-30-2022 02:54 PM
GK5_Honda
01-05-2021 11:26 AM
Ba_forareason
06-25-2018 01:31 PM
epijimenez
01-07-2010 12:20 PM
zombi
06-21-2007 02:35 PM
Quick Reply: Cooling Issues Catalytic Converter delete + cold air intake
