Different tire brands on Fit?
I damaged one tire on a set of Toyos that I got last year. They should have plenty of life in them, but the tire shop wasn't able to order the same Toyos so I have a pair of General tires on order to put on the rear axle. I've read so many different opinions on whether it's okay to mix tire brands as long as the pairs on each axle match so thought I'd ask here.
The tires I have: The General tires pair which I will put on the back axle:
I've read that you can generally mix brands as long as they are the same on each axle and the tread and size is not too different. The size should be similar to the Toyos, but the tread does look different. Any tire experts here want to weigh in on if it's a big deal to be driving on these on my Fit?
It’s not ideal but could be a whole lot worse. Putting the generals in the rear is a good idea for wet and snow driving. I would simply drive the car like a normal car and not a formula1 car. If you drive with care (as we all always should), you should be fine.
Thanks. My only concern is that I'm in Colorado and winter is coming. I do drive a lot in the mountains but avoid bad weather when possible. It sounds like I'll be alright, but man I can't believe the variety of and extreme range of opinions on this.
Snow tires my friend. They make all the difference. I will never recommend all seasons year round in a snowy climate having had snow tires for the last five years in my own snowbelt state
DannyBoy7783
05-05-2018 03:27 PM
gekkota
03-21-2015 10:02 PM
Goobers
04-28-2011 10:43 PM
